The fluid you use is the same as your radiator, your standard 50/50 mix, if you live in an area where you don't have to worry about the fluid freezing you could also use deionized water. I recommend adding some water wetter or purple ice to it as well. The tank is the small one on the left. Yes there is a pump, its located behind the front fascia on the passenger side.
__________________
||RED|||
04 Saleen S281 #381
Saleen Series IV S/C, Saleen 2.875 Pulley, 05 Fuel Pump, Saleen 14" Brakes, JDM Air Kit, 90mm MAS Air, 42 lb Injectors, American Racing Longtube Headers + Catted X-P
