Went for a wheel alignment today for my 2002 S281 to make sure everything was in spec. The only thing wrong was the right front caster was out of specs at 4.1 degrees, and the cross caster was out of spec at -1.1 degrees. Since you cant adjust caster, how in the world is it supposed to get back into alignment? Does saleen ship cars this way, does anybody else have the same prob?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2002 4.6L 5 spd. S281
Intercooled Vortech S trim and all the avg bolt ons
Dyno #'s w/3.2 pulley@9psi: 405 rwhp/400 rwtq
here are the specs that are set on the car right now:
Left front:
camber: -0.6
caster: 3.0
toe: 0.12
Right front:
camber: -0.9
caster: 4.1
toe: 0.13
cross camber: 0.3
cross caster : -1.1
total toe: 0.25
are these out of spec from saleen specs that i need to do something about it? So when you go get a alignment, i'm sure they are setting them to a stock mustang GT specs, do yall take in saleen's specs and have them adj to that?
__________________
I have the Saleen alignment specs at home. Ill try to remember to grab them and repost later. Alternatively if you do a search function on this forum they are probably already posted.
__________________
||RED|||
04 Saleen S281 #381
Saleen Series IV S/C, Saleen 2.875 Pulley, 05 Fuel Pump, Saleen 14" Brakes, JDM Air Kit, 90mm MAS Air, 42 lb Injectors, American Racing Longtube Headers + Catted X-P
According to the Saleen email I received, here are the specs (for 1999-2004 cars):
Camber: -1 degree per side
Caster: is non adjustable unless car is equipped with camber caster plate
Toe: -1/8th degree toe at each side
Total Toe: -1/16th
Hopefully this helps, but I'm not sure if it is all the information you need, just what Saleen sent me. I have no clue how to adjust the caster and apparently, Saleen doesn't say what spec it should be at if you have CC plates. Hopefully Jared has a better answer about the caster spec.
got them on my car. The car loves having alot of caster. My car handles alot better plus my tires wear alot better. Less feathering on the edges. I have a printed sheet of when I went last. I can find the specs and let you know whats good for me.
