Saleen, Roush and Boss Mustangs Discussions on Saleen, Roush, and late model Shinoda Boss Models within. SVT models, check the 4.6L section.
running rich bank 1 & 2 saleen
Old 05-26-2015, 03:55 PM
arquick
arquick's Avatar
Default running rich bank 1 & 2 saleen
I keep getting check engine light for running rich in bank 1 and 2. The car is a 2005 mustang GT with Saleen super charger. Has 100lb injectors all necessary fuel modifications all done by Saleen. The charger has been on since the car had 20k miles now it has 50k and now im getting that code. my wide band gauge says it isn't running rich and performance seems all the same. Need help
arquick is offline
Old 05-26-2015, 04:08 PM
arquick
arquick's Avatar
Forgot to mention after I changed the spark plugs on the car this started. The spark plugs where the originals and the gap was way over recommendation, they also looked horrible. The car would sputter a little in the higher rpms the new plugs solved the problem but now I have these codes... no misfire or running rough so I wouldn't suspect a bad spark plug especially not on both sides of the motor.
arquick is offline
Old 05-26-2015, 07:32 PM
kirk35
kirk35's Avatar
First thing I would do is calibrate the wideband. Innovate recommends a free air calibration every 3 months or 10k miles.
If the wideband calibration is good I'd move on to replacing the O2 sensors and see if the problem goes away.
I'd also think about going with a smaller set of injectors, you're running enough injector to easily support 1200 HP. I wouldn't be surprised if it is running rich, the injector pulse width can only be scaled back so far and I doubt it's enough to keep you from being overly rich at idle.
kirk35 is offline
Old 05-26-2015, 09:12 PM
arquick
arquick's Avatar
Sorry guys I missed types there 42 lb injectors not 100
arquick is offline
Jb145700
08-21-2022 06:37 AM
uedlose
09-10-2015 03:30 PM
TimeLord101
09-04-2015 09:27 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: running rich bank 1 & 2 saleen
