Old 10-15-2015, 07:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
Print Wikipost
what are common 2005 Mustang Problems
Old 02-12-2010, 10:52 AM
Matafy
Matafy's Avatar
Exclamation what are common 2005 Mustang Problems
Are there any problems with the 05? Since it was the first year production of the S197.
Matafy is offline
Old 02-12-2010, 10:55 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
There are many of them and many TSB's on them....water leak issue, frozen e- brake issues...etc....try doing a search and you dont have to look far as just a few threads above there are stickies that will give every problem and fix you can find....
EDIT: I dont want the 05 guys and gals to think I am slamming the 05....I have been on this forum and many others for yrs and know of the many issues that some 05's have (not all)......no car is created equally well unfortunately....
mygt500 is offline
Old 02-12-2010, 11:09 AM
Margarita Girl
Is the tide gonna reach my chair?
Margarita Girl's Avatar
I bought mine new in '05 and the car has never been back to the dealer.
What did break was the back seat release **** on the passenger's side.
Margarita Girl is offline
Old 02-12-2010, 11:49 AM
rdsx18
rdsx18's Avatar
I bought my 05 used with 21000 miles on it. I have 35000 on it now, no problems yet.
rdsx18 is offline
Old 02-12-2010, 07:58 PM
0NF1R
0NF1R's Avatar
05 here and nothing major...havent heard of the 05's having any kind of "bug" like issues...my beast is for sale too :-)
0NF1R is offline
Old 02-12-2010, 08:35 PM
Nuke
Nuke's Avatar
Get familiar with the TSB's as mentioned earlier.
Nuke is offline
Old 02-12-2010, 08:48 PM
ut4126a
ut4126a's Avatar
50k Miles on mine, and not one problem. Ford Reliability, Knock on Wood.
ut4126a is offline
Old 02-13-2010, 03:04 AM
Matafy
Matafy's Avatar
What is this TSB you all talk about?
Matafy is offline
Old 02-13-2010, 05:18 AM
loots06
loots06's Avatar
One of the worst problems is funding the mod bug. I'm sure that's pretty common. LOL
loots06 is offline
Old 02-13-2010, 07:02 AM
07 Stang
07 Stang's Avatar
Technical Service Bulletin ID
Description
04-9-6 BODY-PAINT-IRON PARTICLE REMOVAL-INDUSTRIAL FALLOUT-ACID RAIN NEUTRALIZATION
04-14-7 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES-SERVICE TIPS
04-16-1 ENGINE MISFIRE OR ROUGH RUNNING-COIL ON PLUG (COP) IGNITION SYSTEMS-WDS COP KIT DIAGNOSTIC TIPS
04-24-14 GENERAL PCM PROGRAMMING PROCEDURES
04-26-16 WELD BONDING PROCEDURE
04-24-20 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED MANUEVERS (SUPERCEDES 04-17-5).
04-24-5 REAR WINDOW DEFROSTER GRID-INTEGRAL ANTENNA DIAGNOSIS AND REPAIR-TERMINAL TAB REPAIR
04-26-22 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTICE TROUBLE CODES (DTCS) P035X AND NO DRIVABILITY SYMPTOMS-4.6L 3V ENGINE
05-3-1 MAF DIAGNOSTIC SERVICE TIP-VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
05-4-8 FUEL FILL SLOW, OR DIFFICULT TO FILL
05-6-9 INTERMITTENT CD PLAYER CONCERNS
05-6-15 AIR BAG WARNING LAMP ON-DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53-VEICLES BUILT BEFORE 10/02/2004
05-7-3 AXLE WHINE-VEHICLES BUILT THROUGH 11-15-2004
05-8-6 EXHAUST VIBRATION AT 850 RPM-4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-8-8 GROWL-GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION-TR3650 MANUAL TRANSMISSION-VEHICLES BUILT BEFORE 1-15-2005
05-9-3 INTERIOR PLASTIC TRIM-PAINT-TO-MATCH AND REPAIR-INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-9-11 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT-VEHICLES BUILT BEFORE 4-8-2005
05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-15 MIL AND ETC LAMPS ON WITH BOTH DTC P2106 AND P2135-VEHICLES BUILT 11-29-2004 AND PRIOR
05-9-18 DISCHARGED BATTERY-CHARGING SERVICE TIPS
05-10-19 INTERMITTENT CD PLAYER CONCERNS-AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS SUPERCEDES 05-06-09
05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135-VEHICLES BUILT 11-29-2004 AND PRIOR (SUPERCEDES 05-09-15)
05-15-2 GROWL-GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION-TR3650 MANUAL TRANSMISSION-VEHICLES BUILT BEFORE 2/21/2005
05-15-8 TICKING AND-OR KNOCKING NOISE FROM ENGINE-4.6L-5.4L 3V
05-15-12 FUEL FILL SLOW, OR DIFFICULT TO FILL-VEHICLES BUILT BEFORE 4-26-2005 (SUPERCEDES 05-4-8)
05-15-13 FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-16-12 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES-SERVICE TIPS
05-17-14 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10 BRAKE NOISE-VEHICLES BUILT BEFORE 3-8-2005
05-18-7 WIRING-SOLDERING AND CRIMPING REPAIRS-SERVICE TIPS
05-19-10 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT (SUPERCEDES 05-17-14)
05-20-2 REAR AXLE NOISE
05-21-2 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS
05-22-8 WDS COP KIT DIAGNOSTIC TIPS-COIL ON PLUG (COP) IGNITION SYSTEMS-ENGINE MISFIRE OR ROUGH RUNNING
05-23-17 DIAGNOSTIC TROUBLE CODE (DTC) P0340/P0344/P0345/P0349-4.6L 3V AND 5.4L 3V
05-24-6 CONVERTIBLE SYSTEM CONCERNS
05-25-15 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020-4.6L 3V
06-1-5 DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS
06-2-9 DTC P0340-P0344-P0345-P0349-4.6L 3V AND 5.4L 3V (SUPERCEDES 05-23-17)
06-3-13 FUEL FILL SLOW, OR DIFFICULT TO FILL
06-4-1 RATTLE/NOISE FROM CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-4-2 BATTERY SERVICE-OPERATION OF BATTERY EYE-CHARGING SERVICE TIPS (SUPERCEDES 05-09-18)
06-4-7 TICKING AND-OR KNOCKING NOISE FROM ENGINE-4.6L-5.4L 3V
06-4-9 A-C COMPRESSOR NOT OPERATIONAL-LOW FREON-SHAFT SEAL LEAKS
06-5-4 PARK BRAKE CABLE FREEZING-REAR BRAKES DRAGGING
06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020-4.6L 3V (SUPERCEDES 05-25-15)
06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE
06-9-11 LOUD TICKING NOISE-3-VALVE ENGINES-STUCK LASH ADJUSTER
06-10-1 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE-REVISED COMPRESSOR CLUTCH
06-10-10 AUDIO/NAVAGATION SERVICE AND ORDERING PROCEDURES
06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE
06-10-5 5R55S-TRANSMISSION FLUID LEAK
06-12-11 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS (SUPERCEDES 5-21-2)
06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE-REVISED COMPRESSOR CLUTCH (SUPERCEDES 06-10-1)
06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES-SERVICE TIP
06-19-2 8.8 LIMITED SLIP AXLE MOAN-GROAN NOISE DURING LOW SPEED TURNING MANUEVERS (SUPERCEDES 06-12-11)
06-19-5 CONVERTIBLE TOP WEAR
06-19-8 TICKING AND OR KNOCKING NOISE-STARTUP RATTLE FROM ENGINE 4.6L-5.4L 3V (SUPERCEDES 06-4-7)
06-19-12 DTC P0340-P0344-P0345-P0349-4.6L 3V AND 5.4L 3V (SUPERCEDES 06-2-9)
06-10-10 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-21-07 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES (supercedes 06-10-10)
06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) (supercedes 01-15-06)
06-22-16 CONVERTIBLE TOP WEAR—BUILT BEFORE 10/11/2006 (supercedes 06-19-05)
06-22-18 POWER WINDOW DIAGNOSIS
06-25-15 ALUMINUM BODY PANELS—CORROSION—SERVICE TIP
06-26-01 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-26-02 CARPET REMOVE AND REPLACE
07-01-07 MERCON ATF REPLACED BY MERCONâ V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
07-03-09 MIL ON—DTC P0456
07-04-03 LEATHER-WRAPPED STEERING WHEEL—LEATHER COMING LOOSE
07-05-08 BATTERY SERVICE—OPERATION OF BATTERY EYE—CHARGING SERVICE TIPS
07-05-13 DISCHARGED BATTERIES—VEHICLES IN STORAGE/LIMITED USAGE
07-06-07 SPOILER/DECK LID CONTACT
07-10-03 AIR BAG WARNING LAMP ON—DTC 2295 IN RESTRAINTS CONTROL MODULE AND LAMP FLASH CODE 22—BUILT 3/1/2007- 4/15/2007
07-12-03 RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS)—SERVICE TIPS
07-14-06 WATER LEAK—FRONT FLOOR AREA
07-18-01 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT—VEHICLES BUILT BEFORE 4/8/2005
07-18-02 FRONT END NOISE OVER BUMPS
07-19-01 CONVERTIBLE TOP WEAR—BUILT BEFORE TSB 10/11/2006 (supercedes TSB 06-22-16)
07-20-03 CONVERTIBLE TOP—TENSION CABLE NOISE—BUILT TSB BEFORE 12/1/2006
07-21-12 FUEL FILL SLOW, OR DIFFICULT TO FILL TSB (supercedes TSB 06-03-13)
07-22-08 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS (supercedes TSB 06-19-02)
07-23-01 GRUNT/CREAK/SQUEAK/CHIRP NOISE FROM THE LOWER CONTROL ARM BUSHING OVER BUMPS—BUILT BEFORE 2/28/2007
06-15-2 SPARK PLUG REMOVAL INSTRUCTIONS—5.4 3V
08-17-03 CONVERTIBLE—REAR QUARTER GLASS—TORN/SEPARATING QUARTER GLASS DIVISION BAR
08-04-02 COLD START FEAD HOOT—WHISTLE NOISE / BUILT BEFORE 1/28/2008
07 Stang is offline
Quick Reply: what are common 2005 Mustang Problems
