Metal on metal sound
Old 05-01-2013, 11:18 PM
Rshustler1
Rshustler1's Avatar
Default Metal on metal sound
So lat week I changed my spark ifs without breaking 7/8 and the last one (driver side closest to fan) broke, $100 later and 20 minutes with the lisle tool and I got it out and replaced, while doing maintenance I changed the fuel filter, I also added a set of under drive pulleys... (I know too much at once) and since all that I feel like I lost some power and the engine sounds like its knocking a bit with a screeching sound loudest at the front of the drivers side, also the ad ratio seems a lot more active on hard revs,
Could it be pb blaster burning off still? Only drove for 10 or so miles)
All plugs and coils are secured tightly and sufficiently.
http://youtu.be/EFSjQe2lHPA
Rshustler1 is offline
Old 05-01-2013, 11:39 PM
Rshustler1
Rshustler1's Avatar
Just to note its am 05 gt with c&l Cai, Mac mufflers, bama tune, stack pulleys, 3.73s
Old 05-02-2013, 07:06 AM
BrazenStang
BrazenStang's Avatar
What plugs did you use? anything but copper plugs will cause issues. did you use dielectric grease on the cop's? and for future changes I hope you used anti-seize!
why would there be pb blaster in the cylinder? please provide more info
Posted from MustangForums.com App for Android
BrazenStang is offline
VistaBlueFrank68
VistaBlueFrank68's Avatar
Try some spray Belt Dressing for a slipping pulley.
VistaBlueFrank68 is offline
Old 05-02-2013, 09:05 AM
edwin108
edwin108's Avatar
Do your under drive pulleys look like they are wobbling while the engine is running? Is your belt tracking straight?
edwin108 is offline
Old 05-02-2013, 09:11 AM
Rshustler1
Rshustler1's Avatar
The belt appears to be tracking straight and no wobble in the pulleys I torqued them down like I was supposed to.
I used ht1 plugs and anti sieze and boot grease the pb blaster is from when I changed the plugs I used it to loosen some of the carbon
Old 05-02-2013, 10:14 AM
edwin108
edwin108's Avatar
Try running the engine briefly with the belt off to see if the sound is being caused by the belt/pulley system. Also, how much PB blaster did you use?
edwin108 is offline
Old 05-02-2013, 11:51 AM
Rshustler1
Rshustler1's Avatar
I'm not sure on the pb blaster I know less than half the can but no exact measurement, ill try the belt off tonight and update as such
Old 05-02-2013, 10:21 PM
Rshustler1
Rshustler1's Avatar
When I got home I checked for the sound and it was gone the vehicle is still running odd just no screeching sound
Old 05-03-2013, 09:24 AM
edwin108
edwin108's Avatar
Is the engine misfiring?
edwin108 is offline
Quick Reply: Metal on metal sound
