Oil coming from bellhousing plug.
Old 10-13-2013, 08:02 PM
Sammy_koelle
Sammy_koelle's Avatar
Default Oil coming from bellhousing plug.
So I just recently acquired an 04 automatic 40th Annv. Mustang and today when I got under it after driving , the plug was wet with what appeared to be oil. I wiped it down, drove another mile or so & there was only a little (maybe the eq. Of 3 drops) around the plug.
I searched a little and read that it could be:
Oil pan leak
Valve cover gasket leak
Rear main seal
Possibly a leftover mess from a sloppy oil change?
From what I've read, wouldn't the leak be a lot worse if it was from the rear main seal?
Are there any other possible causes for this small leak? And how could I figure out where exactly the leak is coming from myself?
Here's pics:
Sammy_koelle is offline
Old 10-13-2013, 08:57 PM
Most likely its either the rear main seal , or the oil pan gasket under the rear main.
That plug looks rubber to me , I would take it out and get under there with a flash light and see if you can see anything.
You could try to look down the back of the engine to see if the valve covers are leaking back there as well.
Old 10-14-2013, 11:46 PM
Sammy_koelle
The inside of the plug didn't have any oil inside of it.
In the first picture you can see a drop of oil coming off that plate & that is where the oil is dripping down.
The mechanic said the same thing you did, either it's the oil pan gasket or the rear main seal but he would have to remove the trans to know for sure.
Quotes me $300 for the rear main & said it would be about the same to do the pan gasket. $400 to fix both at the same time.
Old 10-15-2013, 07:38 AM
petrock
petrock's Avatar
If the oil is red-ish its tranny fluid, if its brown it is motor oil. That plug is to get to the torque converter drain plug inside the bell housing. If you pulled the plug, stuck your finger or paper towels up there and didn’t get an oil then its not your tranny oil pump seal. You can check the back of your valve covers for leaks with a small mirror. The oil would travel down the back of the motor to the spot your looking at. There really isn’t a good/easy way to check the rear main seal or the back of the oil pan gasket without either pulling the motor or pulling the transmission. They are both common leak points.
$300/400 for this job is fairly cheap for a rear main seal and/or oil pan gasket job. I’d do both while your at it.
petrock is offline
Old 06-13-2022, 10:09 PM
Lilpurp
Lilpurp's Avatar
Default ?
Where can I buy one of these rubber seals if mine isn’t there ?
Lilpurp is offline
Old 08-12-2023, 10:29 AM
Alexis432
Alexis432's Avatar
What are these little plugs called
Alexis432 is offline
Tivo304
08-28-2023 12:19 PM
Nick Oliver
10-17-2018 04:22 AM
Dragonus18
09-09-2015 01:21 AM
TimeLord101
09-04-2015 09:27 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Oil coming from bellhousing plug.
