Can it solve the problem
Old 12-10-2013, 04:35 PM
Prpfire3
Prpfire3's Avatar
Default Can it solve the problem
So have a lil oil seeping from head gasket front of motor driver side into the valley out side of motor its only like maybe 3 inches rest is clean.
If i was to re torque the head in that corner could that solve my leak
Prpfire3 is offline
Old 12-10-2013, 06:53 PM
JC316
JC316's Avatar
Thats highly unusual. Are you sure that it's not the valve cover gasket or PCV leaking? As for the question, no, don't mess with the bolts, if it is leaking, you need to change the gasket.
JC316 is offline
Old 12-10-2013, 07:15 PM
bronxbomba63
bronxbomba63's Avatar
I agree with JC, look into replacing your gaskets.
bronxbomba63 is offline
Old 12-10-2013, 07:30 PM
Prpfire3
Prpfire3's Avatar
U know it might be the valve cover gasket i will double check i hop it is bec i don't have the money to replace head gasket. I bet its crazy exspinsive
Prpfire3 is offline
mtgldr
02-03-2024 09:00 PM
Golfsito
10-06-2015 11:02 AM
Seanam
10-04-2015 10:15 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Can it solve the problem
