Transmission shifting question
Old 07-02-2014, 02:29 PM
Leebo
Leebo's Avatar
Default Transmission shifting question
Sorry if this isn't the correct way to start the forum as it's my first time posting. I have a 88 LX with a 306 in it not sure the trans but my problem is 2nd gear. IF the car isn't moving I can put it in second gear and shift out to any other gear but if the car is moving second gear grinds but is possible to go into. I usually just skip 2nd and go to third but would like to know what is possibly wrong or ways to fix it without taking it to a trans shop to pay 150 buck to diagnose it. Thanks
Leebo is offline
Old 07-02-2014, 04:03 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Its probably a T5. Common issue with these trannys is bad synchos in 2nd and especially 3rd gear. You can buy rebuild kits for these trannys as well as every other part. They are very common. I got my stuff from Hanlon Motorsports a few years.
Boss_Hotrod is offline
Old 07-03-2014, 08:03 AM
Leebo
Leebo's Avatar
Boss_hotrod
If that is the problem what would be better to go with the refresh or the rebuild? Clueless about transmission not sure where the synchos's would be.
Leebo is offline
Old 07-03-2014, 08:09 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by Leebo
Boss_hotrod
where is west by gosh Virginia are you?? answer this and I may be able to help
mjr46 is offline
Old 07-03-2014, 08:53 AM
Leebo
Leebo's Avatar
Southern West by gosh Princeton area
Leebo is offline
Old 07-03-2014, 09:30 AM
mjr46
mjr46's Avatar
yeah, I'm in the panhandle, little far from me..............check your pm and I mentioned the bare min it'll need....a full rebuild would be a good idea.
mjr46 is offline
Old 07-03-2014, 10:01 PM
Leebo
Leebo's Avatar
I did thanks for the advice may look into a full rebuild.
Leebo is offline
04stangman
09-17-2015 01:45 PM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Transmission shifting question
