how to remove OEM gas cap cable?
Old 07-03-2014, 07:44 AM
RenGen
RenGen's Avatar
Default how to remove OEM gas cap cable?
I got a locking gas cap yesterday but I couldn't figure out how to get the little plastic cable attatched off so I ended up cutting it. but are you supposed to twist it out or does it just pull out? I pulled as hard as I could and it wouldn't come off and I didn't want to accidentally break my fuel door in the process, so I just cut it, but now the little part just hangs there.
this is what I'm talking about
RenGen is offline
Old 07-03-2014, 07:46 AM
RenGen
RenGen's Avatar
Also, since I don't have a wire thing hanging anymore on my new gas cap, when I'm filling up should I just lay it down on the floor or on top of the pump? I don't want to just put it on the car in case the wind blows and scratches it. What do those of you with a fuel cap with no cable thing do?
RenGen is offline
Old 07-03-2014, 08:01 AM
vixr
vixr's Avatar
Back before the cap lanyard was around, I got in the habit of using the gas cap to hold the pump nozzle trigger open...that way you wont forget to put it back on. The cap wont be more than a few inches from the fill.
vixr is offline
Old 07-05-2014, 12:17 PM
tx_zstang
tx_zstang's Avatar
..that connector end snaps in place; you have to pull it out.
tx_zstang is offline
Old 07-06-2014, 09:22 AM
Lifter583
Lifter583's Avatar
I cut the DAMN IRRITATING thing off!!
Lifter583 is offline
Old 07-06-2014, 01:14 PM
RenGen
RenGen's Avatar
^ yeah, I pulled and pulled and even tried to stick a finger on other side to pop it, won't come out.
RenGen is offline
Old 07-06-2014, 09:12 PM
Art161
Art161's Avatar
I would leave it alone, since you don't need to remove it for your new gas cap. I took a look at mine as best I could. Use a flashlight if necessary. It appears that the rubber piece behind the hole is an arrowhead design. That's why you haven't been able to pull it out. On top of that, it appears that the tip of the piece of rubber touches the metal cap on the far side, so it would be difficult to push it out.
If you just have to get it out, I think you're going to have to come up with a way to break the rubber piece apart, with the risk of damaging the paint. You could try to drill it out, use a ***** punch to break it up, slide a screwdriver with a small head and a long shaft in from the side and beat on it or think of some other way to physically destroy it.
As I said, I would leave it alone.
Art161 is offline
Granatelli Sales
01-20-2020 12:34 AM
5.0muscle
01-11-2016 01:17 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-12-2015 04:13 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: how to remove OEM gas cap cable?
