Warranty???
Old 01-23-2017, 11:26 PM
Burst_s550
Burst_s550's Avatar
Default Warranty???
will installing a new exhaust(xpipe/flowmasters) void my warranty??? Only had the car for more than a month. (v6)
Thank you in advance!
Burst_s550 is offline
Old 01-24-2017, 06:48 AM
JimC's Avatar
Warranty coverage is simple. Ford warranties the car that Ford built. If you modify the car it is no longer the car Ford built, it is the car you built. If that modification fails or is determined to be A cause of the failure, then Ford will deny coverage for that repair.
Changing exhaust won't "void the warranty". If you have a problem with the exhaust of course Ford won't warranty it. If you have a rear end failure or engine failure then it is very unlikely a muffler change had anything to do with it.
JimC is offline
Old 01-24-2017, 07:37 AM
proeagles
proeagles's Avatar
Pretty much what he says. ^^^^^^^^
proeagles is offline
Old 01-25-2017, 03:37 PM
movielover40
movielover40's Avatar
Well said Jim.
movielover40 is offline
