Loose Steering Column Help??
Old 02-18-2017, 01:28 PM
Josh M
Josh M's Avatar
Default Loose Steering Column Help??
Having this issue on my 68 Mustang, anyone know what the issue may be?
Josh M is offline
Old 02-22-2017, 12:31 PM
barrylink
barrylink's Avatar
there are two bolts under the dash that could be loose?
barrylink is offline
Old 02-27-2017, 12:53 AM
SteveL
SteveL's Avatar
That is bad.
I agree, 2 bolts under the dash that could be loose. They strap the steering column to the dash.
Also, it looks like you have some play in the wheel when turning. Outside just past the firewall there should be a knuckle that tends to wear causing the play in the wheel.
Also, check where the steering column goes through the firewall, make sure it is not broke or rushed out around the hole.
This will be easy to fix, the only 2 places that hold the column in place are the 2 bolts under the dash and where it fits through the firewall.
When you fix this, check the entire steering system carefully. Make sure it is not loose or worn.
SteveL is offline
synthartist69
03-04-2011 01:11 AM
lx91red5.0HO
10-26-2010 08:13 AM
mackdjh
09-08-2008 07:58 PM
directconnection
06-23-2008 09:48 AM
musickgenius
12-14-2007 02:47 PM
Quick Reply: Loose Steering Column Help??
