Damaged fuel line
Old 02-21-2017, 08:06 PM
PotteryPal
PotteryPal's Avatar
Arrow Damaged fuel line
Fellow Members,
During my current project to replace the fuel tank I found a section of the fuel line near the chassis beam which appears to have been crushed from improper lifting of the vehicle.
My question is, Is it possible to remove a short segment of the fuel line where it is damaged and install some flexible fuel hose on a temporary basis until I can make time for a complete line replacement or EFI system in the future?
My plan was to disconnect the fuel line in the engine bay and clear the line with air prior to cutting the line with a hacksaw, so to avoid any issues with sparks.
What say you?
PotteryPal is offline
Old 02-21-2017, 09:35 PM
Starfury
Starfury's Avatar
I don't see any problems with it. Obviously steel line is stronger and more resistant to physical damage, but fuel hose should work fine as long as you're using a mechanical fuel pump.
Starfury is offline
Old 02-21-2017, 09:40 PM
Gun Jam
Gun Jam's Avatar
If you can flair the ends that would probably be safe.
Gun Jam is offline
Old 02-23-2017, 03:08 PM
bop11
bop11's Avatar
The hose is under suction, so a flexible hose will work. Just don't put the jack there.
bop11 is offline
Old 02-25-2017, 08:52 PM
PotteryPal
PotteryPal's Avatar
This is the crushed fuel line I found. I removed the section pictured and ran a temporary fuel hose until I install my EFI.
The fuel line was more than 80% blocked.
I am surprised the car even ran at all. But, damn does it run good now. Noticeable improvement in power off the line.
