Systemic Issues with 05-?? Mustangs ??
Newbie here. A fellow owner (05 GT) told me of 2 things.
1 The 'feature' where the battery will go dead if let the car sits to long, related to Shaker radio??
2 lower ball joints having short life.
Thoughts?? Other systemic issues??
Thnx
Joey in VA 06 GT conv
BTW, what is the range of related Mustangs, 05-09?? 14??
Thnx
People blame the shaker for the battery, but mine came with the non shaker radio and still did it, turned out to be a weak alternator. Bought a 200 amp one and nver had another dead battery in 8 years.
The ball joints are fine. I replaced my lower control arms for the GT500 after 50,000 miles because the rear bushings were broken and the ball joints were just fine.
The 05 to 06 have an issue with water leaking into the passenger side and damaging the SJB on the kickpanel.
Front seats levers at the back to move seat back forward break
From 05 to early 08 the sparkplugs can break off when taking them out.
Airbag recall
creaks, groans, rattles all ove the place.
Still wouldn't drive anything else. These are small annoyances on an otherwise bulletproof car.
Airbag recall
My 06 v6 got the dying batt., but it's from the cheap CD player. it keeps trying to load cd's, even when the engine is off.
I pull my radio fuse when i park it for a while.
No problems since.
(i was going to get the new Raxiom radio, but Raxiom is cheap, & there are nothing but issues with them.
I haven't had any problems with the radio itself;
i had my ball joints replaced last summer, they are rather weak, i heard.
but our winter ice & snow & potholes don't help!
(& the other posters are right: airbag recall (both drivers & passengers (the newer Stangs only have the drivers side recalled...)
You can get water if the 2 drains under the hood get clogged, but thats easy maintenance...
No problems since.
basically they covered it all. If you park your car in the garage you shouldn't have to worry about SJB getting damaged. Several write ups on the spark plug removal. If you do break one there is a tool to get them out. The plugs are a two piece which is the dumbest thing i have seen. Generally speaking the cars are solid if there is good maintenance being done. Oil catch can will help as well but its not anything you must do. Tranny catch can is a good addition.
All modern computer driven cars will lose their battery over time if left sitting for extended periods. There is always a small draw to maintain memory. I remember back when BMW 7 series would go dead sitting at the airport for more than 10 days while the owner was on vacation.
Am I the only one that noticed his name and am curious? 427impala huh? Year? Pics?
All of the above mentioned items pretty much covers the common issues. Most are easily resolved and/or avoided.
I have not experienced any issues with my lower ball joints, however I only have 20k on my car.
I owned a 2005 GT and now still have my 2008 Shelby GT and both have the stupid gas tank issue that hasn't been mentioned.
It's a long story, but basically you could have problems trying to fill your tank with gas. The backpressure will keep shutting the pump off, and you could end up having to squeeze the pump's level about 100 times just to fill up your tank.
It got so bad on my 2005 that I traded in the car. One of those issues that make a car a non-driver. You can't very well put much gas in when all the nozzles are these modern ones that need the thing fully inserted to flow gas.
It has only happened one or two times with my 2008, but this is an issue that most sellers won't let you know about.
