Replaced Battery, now car won't start and key fob doesn't work
My battery died over the winter. I just replaced it with a new battery and now the car will not crank. All electrical functions work (radio, lights, windows, etc...), but the car doesn't start. Also, the alarm key fob does not lock, unlock, or remote start the car. It is an automatic transmission in case the remote start raises that question. I tried 2 key fobs with new batteries. I'm thinking it may be some sort of alarm/theft protection because of the key fob, but who knows. Any thoughts would be much appreciated. Thanks.
It is possible that the key fobs do need to be reprogrammed, but I am not sure how to do it. What I read was to turn the ignition on and off 8 times which is supposed to lock the doors and then allow reprogramming, but this does not work. This may not work because the original master keys do not work to start the car. It seems as though the key chips may need reprogramming.
Did that particular procedure also require the lock button to be pressed on the key remote while turning on/off the key 8 times? Thats how I reprogrammed the key fob on my 99 (from a youtube video I saw) but the newer cars may be different.
If the reprogramming procedure did not work, you might have to take it to the dealer. I programmed two new keys on my 07 (the ones with the remote built in) and they both work fine. Now I have my original keys safely stored and just use the Ebay one. The procedure says to turn the key to the on position 8 times withing 10 seconds, ending in the on position, then press any key on all the remotes you want to program. Remember, it's the ON position, not ACC.
