Infamous bucking
Old 03-25-2017, 10:52 AM
Thomas08GT
Thomas08GT's Avatar
Default Infamous bucking
First post and new account but have found this forum useful for awhile now. I recently upgraded from a 99 to an 08 GT in the past month the car has 65k milesI've installed air raid cai, genavillalalala 62MM Throttle body. Charge motion deletes, Ford racing hot rod cams, pypes cat back, 3:73 gears and of course have the bama tune. Doubt it would be a factor to the problem but also have the hurst shifter. The car has started jerking or bucking at low gear low rpms recently to the point that if you don't change gear it'll give you whip lash. This only happens when first driving it cold or warm. Yesterday the normal knock most of us here when changing gear cruising around town became a repetitive knock while out of gear sitting at a light. I pushed the clutch in and it magically stopped. I'm going to guess the two of these are connected i would assume clutch how ever my diagnostic skills are lacking. Any input would be appreciated. And yes I've tried searching with no answer close enough to start tearing the car apart. Thanks. Side note all of these have been installed within the past two weeks so I couldn't tell you if it started at anyone part
Thomas08GT is offline
Old 03-25-2017, 10:59 AM
howarmat
s197 Junkie
howarmat's Avatar
Assuming the tune is correct it could be the clutch maybe. But that is a lot done at one time so and it could be an airflow issue.
howarmat is offline
Old 03-25-2017, 11:03 AM
Thomas08GT
Thomas08GT's Avatar
I checked vacuum right behind the throttle body and its sitting at 17" it seems the average for horrod cams is 15" if that helps with anything fuel pressure is good as well
Old 03-25-2017, 11:05 AM
Thomas08GT
Thomas08GT's Avatar
I'm stuck on thinking it's the clutch because I want to put lt headers on while I'm under there. Is it possible with the intake being as open as it is now the stock headers are what's causing an issue?
Old 03-27-2017, 07:41 AM
ghunt
ghunt's Avatar
Bucking right after a cold startup is actually normal, especially if you've put on a bigger throttle body. The charge motion deletes help with that but won't completely get rid of it. The cams might exacerbate the problem. Does it do it in other gears besides first?
ghunt is offline
Old 03-27-2017, 08:23 AM
Thomas08GT
Thomas08GT's Avatar
I believe you're right it was a o that's odd kind of buck at first but after the cams it's more of a WTF was that!? Second gear it's like it gets an extra boost of power for a second and then it loses all power just back to back really quick. Bama tunes has been working on data logs for it since last week hopefully they have a fix. Letting it warm completely up before driving seems to be the answer for now. The clutch knocking seems to be a separate problem already ordered a stage 2 ill throw that in and see what happens
Old 03-27-2017, 03:04 PM
what is a "genavillalalala 62MM Throttle body"?? If it's not Ford, that's always my first suspect with driveability concerns like bucking, idle, etc.
Did you have the mods all done at once or over a few months? At what point did the problem start?
Old 04-01-2017, 12:25 PM
flash_xx
flash_xx's Avatar
Mine did it, turned out to be the accelerator pedal. Got a new one and the problem went away. How did I arrive at that conclusion? Easy, I guessed.
Actually I figured it was the pedal because it always happened at the same spot on the pedal travel and it was cheaper than a throttle body. Turns out I was right, I opened the old one up to see what was inside and it's just a potentiometer with some bristles that run through some copper strips.
In your case, I'd try to borrow one from a friend,if the buckling goes away it was that, if it doesn't then it's the TPS, which is also not that expensive.
PS: If you can get a proper tune. My '04 GTO picked up 60HP over the tune it was running by taking it to a dyno and having it tuned by a pro. I bought it used so whatever was in there sucked big time.
flash_xx is offline
Old 04-01-2017, 12:31 PM
flash_xx
flash_xx's Avatar
I hope it's not Granatelli, those people suck. How they are still in business is beyond me.
flash_xx is offline
Old 04-01-2017, 01:02 PM
Thomas08GT
Thomas08GT's Avatar
First chance to open the hood back up today switched out tb for the stock one surprise it's the grantelli tb causing it. The voltage is different from the stock I called them and got a sh!tty reply of how I'm not supposed to be messing with that hopefully American muscle will take it back. And the clutch is still knocking so no connection between the bucking already have a new clutch to put in it next weekend hopefully it's Just a bad throw out
