Wiring - what does this go to?
Old 03-30-2017, 03:18 PM
Gee0622
Gee0622's Avatar
Default Wiring - what does this go to?
I need help please where do these wires connect and what are they for used for located under the glove compartment 2007 mustang gt
I need help please where does this wire connect and what is it for 2007 mustang gt
Gee0622 is offline
Old 03-30-2017, 04:19 PM
JimC's Avatar
Someone installed some aftermarket parts on that car. The top pictures looks to me like you had an aftermarket head unit at one time - maybe was removed and the stock Shaker reinstalled.
The second picture is obviously not a stock connector. It was likely used on a power tap. Is there an "add a tap" fuse in that fuse box (looks like you are looking in the passenger side footwell fuse box)?
What does your dash look like? It may show what you have that isn't standard. If everything was put back to stock then all those wires don't connect to anything now.
JimC is offline
Old 04-01-2017, 12:21 AM
Gee0622
Gee0622's Avatar
Yes I am and I believe there isn't one but I'll check, I have the shaker 500 nothing modified on it but my aux button and the sux port doesn't work at all???? That is another concern I have
Gee0622 is offline
Old 04-01-2017, 07:49 AM
JimC's Avatar
What year is your car? Depending upon the year the AUX button may not be used - 2006 for example it was there but only because on other cars it was used and it was cheaper to use the same head unit across production.
But it definitely sounds like your prior owner had aftermarket equipment on the car and put the stock components back in.
JimC is offline
Old 04-01-2017, 06:12 PM
Gee0622
Gee0622's Avatar
My mustang is a 2007
Gee0622 is offline
dbgrigsby93
11-03-2016 08:04 AM
Ndz98
11-01-2016 04:21 AM
Bubba Jones
10-30-2016 01:33 AM
Armyguy1993
10-01-2016 02:15 PM
whiteguytyrone
07-18-2016 10:52 AM
Quick Reply: Wiring - what does this go to?
