speed density
#21
RE: speed density
well my dad picked up an 88 gt in the summer that had been converted to maf and we are no in the process of converting it back to sd because of the poor performance the maf system is giveing the car , mine will flat out runit hands down . and all i have cai and ud's same as his. now lets talk .
#23
RE: speed density
obviously u have another problem......but whatever......
ORIGINAL: stangbanger87
#24
RE: speed density
ok first off why are we arguing over naf the reason the section was faught for was to get away from the coments of how sd guys need to convert to maf and here you are saying on the sd forum that we need to convert to maf because it is better . and as far as you calling people know it alls sounds like to me that you are the one on here trying to be the know it all because no matter what we say you always have to be right ! so go and convert your to maf and rerun all that wireing and change out your ecu and the money you have spent there i will have used the same cash and gained more hp and while you have converted yours to drop 20hp , makes good sense to me [sm=bicker.gif]so lets stop the arguing and try doing what this forum is intended to do and that is to help guys with sd/and carb issues and show them other ways to make hp with out conversion .
#26
RE: speed density
ORIGINAL: shawnk007
Ok.....Im not saying that SD cant be used in performance applications.... But there is a reason the switch to MAF was made..... Find me someone whos willing to convert their MAF system to SD, then we'll talk.....
#27
RE: speed density
ORIGINAL: OnyxCobra
Lucky for you we have a guy on the forum that did that switch with his '94 Cobra, AdderMK2, he's a very knowledgable individual
ORIGINAL: shawnk007
My car runs a speed density system... so what do you want to talk about
#28
RE: speed density
I can't think of any aftermarket EFI systems that are considered powerful, that are NOT SD. Megasquirt, FAST etc, are SD.
And technically speaking, MAF doesn't measure the amount of air entering and engine, but rather a set of parameters, just like SD. The MAF sensor has a filament in it, and voltage is applied to the filament to heat it to a given temp above ambient. From physics we know that the amount of temperature drop on an object is directly proportional to the mass of air flowing past it(hence the term mass air flow). When the air at a certain temp and pressure flows past the MAF sensor, it tries to cause a temperature drop, so voltage is increased to try to maintain the same temp above ambient, and based on the voltage change the computer calculates temperature drop, and the from the given temp drop(which is calculated) it calculates the mass of air. It still has lookup tables, once it has it's input parameters it adds the fuel based on what the tables say. With SD the computer is measuring changes in voltage/resistance from sensors. With MAF the computer is measuring changes in voltage/resistance from sensors. They both add fuel based on how they've been programmed.
From everything I've read, the manufacturers have only gone to MAF because they felt it would help with mileage and emissions. But many aftermarket EFI setups that are designed for serious power, are SD. MAF and SD aren't all that dis-similar, they both measure electrical changes as input parameters from sensors. Use good sensors, and a good computer, and tune the car right.....what's the difference?
#30
RE: speed density
Speed Density here, I will be using MegaSquirt soon.
No reason to change to MAF if you can get a complete standalone SD system for the same price.
The reason for the conversion is for boost purposes.
