how well will it run ?
i got a few things in the mail ...
ecam
long tubes 70mm tb and rpm2 intake manifold ..
4.10 gears
electric fan
cold air
255lph pump
and 100-150 shot of nitrous ..
its a sd 88 coupe ..
im eventually going to conver to maf when i do sum serious upgrades but how well will it run as is ? a buddy of mine said to not even try it would run like crapo but im not sure if hes right .. any input ?
ecam
4.10 gears
electric fan
cold air
255lph pump
hey there ,
and yes your buddys right well atleast with the cam as the speed density cars do not like cams,injectors or anything like that .
the intake ,headers, and such will be fine , but do your self a favor first swap over to maf and then swap the cam out and such.
The tb will be fine I run a 70mm bbk and have never had a problem. SD cars are fine with cams as long as you stay within the perimeters. That e cam though will be a problem as stated by jtmustang. Everything else should be fine until you switch to maf. I would wait to run the nitrous. You will probably run the nitrous different when you switch to maf anyway. It will save you time and money.
thats what i was also thinking .. im more interested in wot racing not putting around town .. i might just do everything .. if it dosent run too well ill just get the maf conversion done sooner . anyone else think it will run good at wot ??
