Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
F cam?
Old 04-14-2008, 11:30 AM
sultan68
sultan68's Avatar
Default RE: F cam?
if you get a standalone efi like megasquirt..would that fix that or would you still need a different cam for speed density?
sultan68 is offline
Old 04-14-2008, 10:13 PM
dimebag
dimebag's Avatar
Default RE: F cam?
if you did that, yes you could run what ever the hell you wanted... however if i had that the f cam would not be my cam of choice
dimebag is offline
Old 04-15-2008, 11:31 AM
sultan68
sultan68's Avatar
Default RE: F cam?
thats cool..i didnt know that
ill have to seriously consider doing that before i buy anything for my car
megasquirt is one of the best ones isnt it? are there any others?
sultan68 is offline
Old 04-16-2008, 09:07 AM
itsslow
itsslow's Avatar
Default RE: F cam?
ORIGINAL: dimebag
itsslow... what springs and lifters? i might have an idea...
springs are stock and the lifters im not too sure about.I would like to find a way to
maybe get mycar running better with that cam.
itsslow is offline
Old 04-16-2008, 07:35 PM
stangbanger87
stangbanger87's Avatar
Default RE: F cam?
xfi by fast is another one available stand alone
stangbanger87 is offline
Old 04-17-2008, 11:06 AM
dimebag
dimebag's Avatar
Default RE: F cam?
first of all stock springs are junk and not enough for that cam. im half busy right now but to give you a general idea...keep stock lifters and get new springs, whats the lift on a e cam? .499/.510 or something like that? id like to see your spring pressure up inthe low 300s
dimebag is offline
Old 04-21-2008, 09:46 PM
boss_5pt0
boss_5pt0's Avatar
Default RE: F cam?
You can't trust everything that Summit says. I bought a cam kit that was supposed to be specifically compatible with my car. It was a sn95 5.0. It came with flat tappet lifters. WTF?! Friggin tards!
boss_5pt0 is offline
Old 05-18-2008, 11:58 PM
jayh88gt
jayh88gt's Avatar
Default RE: F cam?
e303- 220/220; .498/.498; 110
f303- 226/226; .512/.512; 114
ive always wanted to try f w/sd but never have. it works really well w/carb
jayh88gt is offline
Old 05-19-2008, 06:49 AM
stangbanger87
Default RE: F cam?
i have the fcam in my 94 f-150 wich is a mass air vehicle and it still doesn't idle right , you have to help the truck along forabout a min then it will take and hold idle at 1k .
Old 06-10-2008, 07:24 PM
aru_next
aru_next's Avatar
Default RE: F cam?
just go mass air, or put a carb on it if you want to go with the f cam, I have a f cam I getting ready to put in my car but Im going to carb
aru_next is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: F cam?
