Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
new to SD
Old 06-17-2008, 03:58 PM
1988GTstang
1988GTstang's Avatar
Default new to SD
i have a 1988 GT mustang and its my first my car so its my first build. My question is im building up the 302 instead of swappin motors. everybody tells me to convert to MAF because SD cant be tuned? Is this true? And if it can be tuned how hard is it and can i get the same power?
1988GTstang is offline
Old 06-17-2008, 05:51 PM
stangbanger87
stangbanger87's Avatar
Default RE: new to SD
well the sd can not be tuned but it can be worked with . in changeing out the cam you have to look for cams that have a 114 lsa(lobe seperation angle ) the injectors can only be the stock 19# inj's . you can run nitrous on them and get good power , my 87 has trick flow track heat intake ,twisted wedge heads and a65mm throttle body with a 100 shot under drives cold air and hit 315hp to the rear tire with the spray on.
stangbanger87 is offline
Old 06-17-2008, 06:54 PM
1988GTstang
damn then i got no choice but to swap over to MAF
Old 06-18-2008, 06:18 AM
stangbanger87
well for the same amount as the new conversion kit plus a little more coin you can go with xfi or mega squirt for a sd ecu stand alone , which are very tuneable and make awsome power and are more relieable than maf . i have a ford truck that is mass air with the f303 cam in it and it has idle issues with maf so they aint no better in my opinion.
Old 06-18-2008, 07:25 AM
86blkconv
86blkconv's Avatar
you can run 24lb injectors on speed density, i have them in my car and they run and idle good! speed density can be worked with its just just a little tweaking and you can have a great running car. check out my sig, its a heavy convertible and i weigh 235 and i have put up some decent times (i think!!) it runs real strong and i can still get about 18mpg on highway trips!! i would notcount out speed density right away! the major thing is deffinetly thecam, but there are some cams out there that are very speed density friendly!
86blkconv is offline
Old 06-18-2008, 07:27 AM
1988GTstang
i think im going to swap over to MAF...i found an ECU-housing-and harness for about $200
Old 06-19-2008, 05:20 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
its dimebag
few things
**** maf
**** your 24s ****, id really like to see that, because your the 1st to ever pull that off...
and why are you swaping? SD is fine, my SD car runs its ***** off
and stangbanger... you didnt tell me you dyno'd ur ****... nice numbers !!! how big of a shot?
WhiteFoxGT is offline
Old 06-19-2008, 07:01 PM
jayh88gt
jayh88gt's Avatar
i got 24's and had em in my old 87 too
sd can rock, just leave the cam alone. they can work but drivibility suffers
as far as power adder, you can make sd work till about 425rwhp, but your forced to run fmu w/boost
jayh88gt is offline
