Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-19-2009, 01:35 AM   #21
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
nice running 289
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-13-2009, 09:01 PM   #22
cornfused
cornfused's Avatar
Vehicle: 1987 Notch
Smile
This thread has me thinking,
I was gonna get an edelbrock performer 600 for $275 from summit but,
I can get my buddy's new in the box street demon 750 for about $400 or $500.
So now I thinking which would be better?
Here's the application-
87 Mustang
306"
AOD
Crower cam
Grind/lobe center
222HR228
112*
Advertised duration
Intake Exhaust
282* 286*
Duration @ .050"
Intake Exhaust
222* 228*
Gross lift
1.6/1.6
Intake Exhaust
.496" .512"
Performer rpm intake
Stock heads
Long tube headers
Stock 85 ignition
For street use
Thanks for any help!
__________________
1987 Notch
306", AOD/shift kit, Holley carb,crower cam and long tube headers.
cornfused is offline   Reply With Quote
Old 09-14-2009, 05:22 PM   #23
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
The key wording in his staement is 950 base,it doesn't mean it is a 950 carb,Patrick puts 950 bases on some of his carbs to increase booster signal.The venturis may only flow 750 or 800.
Use the Demon you will be much happier with it.I think the cam is a little small,I would run something in the 230-240 range a .050.I ran a Crower flat solid 238-242 .050 .477.488 110 TFS high ports 1 3/4 headers 823 cfm Gold Claw RS DP, Offy Port-o-Sonic 4.10 gears.went 11.60 at 115 on 26x10 M/T slicks.
Sorry did not see it was HR.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
302, 500, 600, 65, calculator, carburetor, cfm, draft, intake, mustang, sbf, setup, setups, side, sizing, webber
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
