Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-08-2009, 01:29 AM   #1
F150 StrokerCobra
Default ARG help.. fuel delivery question
putting a carbed 1996 explorer 5.0Ho with gt40 heads and a mild cam with edelbrock air gap intake and holley carb
yeah i got the whole plumbing kit from summit..complete with pump filters connections and all. all i need to know is..
how do i put it to get fuel from the tank??
i was thinking about leaving the complete thing that goes in the tank where the fuel guage gets its reading. and remove the pump and the small filter underneath then just tap into the original fuel lines above the tank to the pump..
how did u do it ??
its this kit btw
http://store.summitracing.com/partde...0&autoview=sku
it says the pump is a pusher not a puller. so it cant suck the fuel out of the tank the fuel has to be gravity fed to it.. do i need to tap on the bottom somewhere on the tank and connect a fitting?? or what? help me.. thanks.
__________________
--==Jurgen==--
Under Construction: 1989 F150 reg cab longbed
5.0 HO, Comp custom cam 0.18/0.24 @0.50 0.513Lift , Flowtech LT's, hooker aero chambers, GT40 heads, Edelbrock Air Gap Performer intake, Holley 650dp Carb,
F150 StrokerCobra is offline   Reply With Quote
Old 05-08-2009, 01:55 AM   #2
F150 StrokerCobra
the answere to all my problems!!
ill just connect this to the tank will it work?
http://store.summitracing.com/partde...t=SUM-TANKKIT3
__________________
--==Jurgen==--
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
