I'll say this again but nobody will read it because it's me and the post is not going to be a novel. I just bought a set of GT40P's for $175 and I plan on porting, doing some bowl work, and running larger unshrouded valves. I am stepping to a custom cam and a stall that is around 2000 to 2400rpm.
__________________
88 LX Notch, 302 Edlebrock Performer RPM, Holley 750, Hooker long tubes, 3 inch O/R X pipe w/flowtech 3 inch in/out 2 chambers, TFS 1 cam, ported E7's, Detroit locker, 3.73's.
You should know that sometimes results vary from engine to engine car to car. The results you get in your area can differ in mine, you should know that. I'm all for eliminating restriction in the exhaust but the entire car and exhast system has to work as a whole. If the exhaust gases can make a smooth transition out of the exhaust it works to the best power of the car. If the exhaust is to large the air curls up and the next pulse wave has to hit a wall of air and it creates a domino effect and instead of the exhaust being pushed down the pipe the flow slows down becuase of turbulance in the exhaust. There is a point where exhaust gets to small and a point where it gets to large.
..... and I am the "hack regarding airflow dynamics"?........
That is incorrect and where the misinformation lies.
1. Exhaust gases do not change state to solids becoming unmovable matter.
2. A 3" ID has 44% more cross section area than a 2.5" ID exhaust, even if all of the 44% increase over the 2.5" exhaust in the cross section gets turbulent or "plugged" as you describe it, wouldn't it be the same as having a working 2.5" pipe?
3. Is 1 CFM trough a 4.9 Sq." area pipe (2.5" ID) = 1 CFM through a 7.1 Sq." area pipe (3" ID)?..... guess which one will look slower? .....but the flow is still 1 CFM for both.
4. So that domino effect decay due to turbulence at the silencer, causes it to get theoretically plugged, and those harmonics will reach the exhaust port?
5. Do you know the easiest way there is to check for that BS conclusion? .... measure exhaust system back pressure with a gauge, or get a little technical and use a transducer with a datalog device. If back pressure does not increase in the system through its working RPM's and engine load conditions.... guess what that means regarding the air walls creation due to turbulence?
Have I done it?...... Guess.
__________________ ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
Great find, suggest not to spend that much money on them though, by the time you add up all the costs to upgrade pedestal to studs, guide plates, new valves, port work, etc....... you'll know what I mean. The GT40p shown below is one of a set I have for a customer.... total cost when finished?... you don't want to know.
They'll work great on a 302, but not on a 331/347..... or better worded, there are better options to ensure engine "breathability" at a similar cost.
I doubt that will happen because a Moderator is involved in the conversation.
Oh I see....since I'm involved, I'm not allowed to take a position and if I do all of a sudden I'm an instigator and nutswinger amongst other things you have called me....all the while I have yet to name call......get the instigator part straight, yeah that's right I saw the "instigator" cheap shot you took at Stinkinlinkin in his thread.....low real low.....from this point forward any off topic comments of yours will be deleted and PA is next, no more warnings
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
Portmaster this is one and only warning. it is a debate resorting to name calling will get you no where but a trip to banned camp. when a question is presented to you answer the first time asked so people do not have to continue asking. answering by saying someone is swinging from someones nuts is the correct answer FYI.
this thread is done if you have any questions PM me and i will take care of it.
Not always but in this one I nailed it. You had to call for backup in a fight that you can't win as far as I'm concerned. Thats pretty chicken chit in my book. Is that how you play when cornered?
Why is it you feel so compelled to fight with people on the forum? This board isn't your soapbox to spout off when people disagree with you. You've been a constant source of problems for this forum, and despite being asked/warned by MF staff, your bad behavior continues.
Quote:
Originally Posted by Portmaster
I'm sure you will take the cowards way out and ban me but I really don't give a flying rats azz.
Since you don't care, neither do I - BANNED
__________________ 1985 SSP Mustang - California Highway Patrol Unit #E408395
We are the music makers, and we are the dreamers of dreams - Willie Wonka
