Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-22-2009, 12:57 PM   #11
86blkconv
Vehicle: 86 convertible
Quote:
Originally Posted by 331strokerstang View Post
ok 86blkconv what computer are you running, because i put a rering kit, and 351W heads w/ 60.4cc com. chambers, and mine idles like ****, your ignition and fuel and timing, just every detail would be helpful
honestly i dont know what computer is in it, i would imagine it is the factory 86 speed density computer in it. i will have to look and check it out. for the fuel pressure im am running 42psi w/vacuum off, and the timing is 16 degrees when i know im not spraying it and about 12 degrees when i know i am spraying it! TPS right at .980! i set the idle right at 1000rpm and it idle's pretty good!
__________________
86vert,347 w/JE Pistons Eagle H-Beams,AFR165,Speed density,home ported cobra lower,70mmTB,AFM P.Pipe,crower 15511,1.7rr,24lb inj,lakewood90/10,50/50,tremec3550,3.73
BFG Drags(302 times) 12.62@107.8NA 1.65 60ft 11.68@117w/75shot 1.62 60ft
86blkconv is offline   Reply With Quote
Old 08-22-2009, 03:13 PM   #12
331strokerstang
Vehicle: 1987 Ford Mustang GT
Ok thank you i will try adjusting those things, yes please check your computer and tell me the numbers
331strokerstang is offline   Reply With Quote
Old 08-23-2009, 03:22 PM   #13
jayh88gt
my blower works good sd too
your better off upgrading the heads and intake first you'll get more power that way a 347 is just gonna get you some torque and move the powerband down you'll only gain 10hp with stock heads from a 347
jayh88gt is offline   Reply With Quote
Old 08-23-2009, 03:25 PM   #14
fs308
1995 Ford Mustang
My Garage
fs308's Avatar
Vehicle: 87 piece of sh!t
how did you come up with that number?
__________________
Project:POS
fs308 is offline   Reply With Quote
Old 08-23-2009, 03:35 PM   #15
jayh88gt
back in the day a 351 crate motor with e7te's was only 235hp.
but really lets think about it, stepping to a 347 your increasing stroke .4". your running a 4"bore still with the same pathetic heads, hp wise you'll just make the same numbers 400rpm sooner. you will gain torque because torque is in fact a function of stroke and cubic inches, hp however is not. hp is based on cfm not cubic inches. this is why i said get better heads and intake- cfm- airflow
so in theory it wont make 10more hp but i think it will but thats about it. change the top end components and its a whole different ball game but stock e7te's are door stops they dont flow very well
Old 10-08-2009, 06:24 PM   #16
Foxbody87
1987 Ford Mustang
Foxbody87's Avatar
Vehicle: 1987, Ford, Mustang GT
Send a message via Yahoo to Foxbody87
Just stole a used 302 block off a guy for dirt cheap that i'm planning a 347 build with, i already have a set of refurb'd e7te's... If i were to get the heads ported and the whole nine, would i be able to get them to flow good enough to get some good gains from the 347??
__________________
BBK-ssi manifold, BBK 70mm TB, BBK 1-3/4" Long tube headers and cat'd H-pipe, Flowmaster Delta flow exhaust, mass air conv. with 75mm maf, 30# injectors, UD pulleys, Alum. radiator w/ 2-12" electric fans, Weiand alum. water pump, MSD distro., blaster II coil, and 6al box, FRPP 9mm wires, battery relocate, 3.55's, MGW short throw, Eibach Pro springs, KYB shocks, Steeda HD rear-sway bar.
Foxbody87 is offline   Reply With Quote
Old 10-08-2009, 11:36 PM   #17
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
you are just wasting money on those E7 boat anchors...
you wont even break 300hp
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-14-2009, 11:11 PM   #18
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I'd be utterly embarrassed to say I had a 347 putting out well under 300 hp with that combo
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 10-18-2009, 06:07 PM   #19
Bobert
Vehicle: 1990 Lx
i'm loving the e7 chirps haha
I guess just spend the cash and get better heads. Even though there going to run you probs the same price as the 347 kit ( a cheap one )
Can you run a 347 on the stock computer (1990) ? with what mass and injectors?
or do you need to chip in and run all sorts of tunage?
__________________
1990 5.0L Lx, stock
There's no replacement for displacement.
Bobert is offline   Reply With Quote
347, e7, fast, heads, horsepower, sale, xfi
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
