i have a 650 dp holley on my car if u rev it up slowly the runs great but if u just open it all the way up she falls on her face and then backfires though the carb a buddy told me the power valve is shot is this right
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1988 Gt TTOPS 1 1/2 IN LOWERING SPRINGS KYB ADJ SHOCKS MSD COIL FRPP WIRES LONG TUBES O/R X PIPE FLOWMASTERS KING CORBA CLUTCH MGW SHORT THROW SHIFTER F CAM CRAN VALVE SPRINGS ROLLER ROCKERS 650 DP HOLLEY UPPER & LOWER CONTROL ARMS 4.10 GEARS
Not to sound like a dick, but why are you running a carburetor if you have no idea how they operate? You need to seriously go out and get a carburetor book from Barns n Noble and understand how a Holley works. A carbureted car will never run right unless you tune the carb to do so. And you can destroy an engine if you're badly tuned.
As far as your problem, the accelerator pump delivers fuel as you open the throttle, it's operated by a plastic cam screwed onto the throttle linkage. Make sure it's all working properly and try a bigger cam. If the pump shot is too lean then you can get carb backfires when you hit the throttle.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
With the car OFF look down the barrels of the carb. Press the accelerator back and look for a small but strong stream of fuel coming from the squirters at the top of the venturies. Depending how your carb is set up the rears will follow quickly
__________________ ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
