Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-30-2009, 06:58 PM   #1
427cobra
Vehicle: Shelby AC Cobra Replica
Default Fuel pressure - what should it be?
I have an aftermarket EFI system that uses a Ford EEC4 control unit from a 1989-1993 mustang gt. It has a Mallory adjustable fuel pressure regulator and is a return type fuel system. The regulator has vacuum connection that raises or lowers fuel pressure 1:1 with manifold vacuum/pressure. Engine has 36 lb/hr injectors in it.
With the vacuum line disconnected, what should the fuel pressure be set at? The fuel pump only runs for a few seconds when the key is turned on, so I pull the vacuum line to check the pressure. I believe this is a correct way to set the pressure.
427cobra is offline   Reply With Quote
Old 07-14-2009, 12:53 AM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
I'm looking into the same thing- what the correct fuel pressure is for the eec 4 5.0L.
Is the aftermarket rising rate fuel regulator necessary? I thought that if it's regulated to the specified pressure- the injectors would operate correctly. I mean, it's the EEC that is adjusting the injectors movement electronically, not by changing the pressure (mechanically).
Apparently, the factory FPR is adjusted by engine vacuum also.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
1989, 30, 351, be, carbs, fuel, gt, injectors, lb, low, mustang, press, pressure, regulators, vacuum
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
