Yes there is a way to wire in the MAFS, without changing out the harness. I recall reading it on a site I found doing a google search on eec4. As I recall it was very detailed.
Depending on the cam specs, I would give you different answers. A lot of valve overlap result in low manifold vacuum. Speed density uses manifold vacuum to determine what the air flow into the engine is. I think a good tuner can cope with mild cams, but MAF handles it much better. However a large cam in and of itself requires different timing (more initial timing) and the extra air that the engine can take in can get things fairly far from what the factory tuning expects. It will need chipped and tuned even with MAF if the cam is above 230 intake durration, maybe less.
If you go to a carb you might as well change out the distributor too, because the ecu will not have the timing right. Tuning a carb and stand alone distributor requires understanding the same needs and have most of the same tools. It is just different ways to accomplish the same things. To do it yourself with EFI has a higher initial cost for the tools (and software). Since you already own the EFI system, I would say stay with it and find a good dyno tuner. EFI runs better than a carb at almost ever condition other than WOT. Long term EFI is less head aches. Once set up it just works. Carbs are affected by everything from air filters to the position of the moon.
