Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-27-2009, 10:06 PM   #11
1988TTOP
Vehicle: 1988 GT TTOP
u need a roller cam not a flat tappet cam
__________________
1988 Gt TTOPS 1 1/2 IN LOWERING SPRINGS KYB ADJ SHOCKS MSD COIL FRPP WIRES LONG TUBES O/R X PIPE FLOWMASTERS KING CORBA CLUTCH MGW SHORT THROW SHIFTER F CAM CRAN VALVE SPRINGS ROLLER ROCKERS 650 DP HOLLEY UPPER & LOWER CONTROL ARMS 4.10 GEARS
1988TTOP is offline   Reply With Quote
Old 08-01-2009, 10:14 PM   #12
JayBanion
1988 Ford Mustang
JayBanion's Avatar
oh $hit your right. That never even came to mind, didnt look close enough. So what do you guys think of the Holley 670? And what would be the best intake?
__________________
F**K THAT FUEL INJECTION S**
88' GT - GT40P's, Comp 986 vavle springs, Comp xe276hr cam, Comp Magnum 1.7 roller rockers, Comp Pushrods, Edelbrock 289 Performer 4bbl intake, Holley 650, BBK Longtubes, BBK shorty o/r H-Pipe, Dumped flowmasters, Ford 9mm wires, Crane PS91 coil, MSD 6A, Ford Racing 4.10 gears, Ford Racing King Cobra clutch, Hurst shifter, Holley Blue Fuel pump, jegs 12 gallon pro-street fuel cell, Holley Regulator, blood sweat and tears
JayBanion is offline   Reply With Quote
Old 08-11-2009, 07:56 PM   #13
JayBanion
1988 Ford Mustang
JayBanion's Avatar
How hard will this be to remove the computer harness. Is it difficult to seperate it from the chassis harness? I have pretty much everything else removed as far as the motor goes, acessories all that. So now Im at the harness part
__________________
Old 08-11-2009, 08:03 PM   #14
1988TTOP
easy they engine harness and the body harness are 2 different harness
__________________
Old 08-11-2009, 08:31 PM   #15
JayBanion
1988 Ford Mustang
JayBanion's Avatar
Dont they link together in a few places. And how do I then go about getting my stock gauges to work?
__________________
Old 08-11-2009, 08:37 PM   #16
1988TTOP
my bad they do for the drivers side by the firewall and the gauges i will have to look to see what colors they r
__________________
Old 08-11-2009, 09:54 PM   #17
SonicBlueFiveSlow
1989 Ford Mustang
SonicBlueFiveSlow's Avatar
Vehicle: 1989 Ford Mustang GT
Underneath the brake booster there's 2 round connectors, a grey one and a black one. That's where the computer harness meets the chassis harness, disconnect them and pull the main harness out, getting the computer connector through the hole in the firewall can be a bit tricky but just work it and it will eventually come out.
As far as the stock gauges, your connections will be made underneath the booster at the 2 connectors I mentioned above. To get the stock tach to work, on the grey connector, tap into the dark green wire with the yellow trace. On the black connector harness, tap into the red wire with the white trace to get your water temp gauge to work and on the same black harness, tap into the white wire with the red trace to get your oil pressure gauge to work. The stock fuel gauge and volt gauges will still work.
Make sense?
__________________
Quote:
Originally Posted by cch View Post
bahaha 'magine there was more side bulge then Rosie O'donnel in spandex.
SonicBlueFiveSlow is offline   Reply With Quote
Old 08-12-2009, 06:12 PM   #18
JayBanion
1988 Ford Mustang
JayBanion's Avatar
Lets say for the tach, by tap into the wire you mean just splice the two together from both sides of the connector?
__________________
Old 08-12-2009, 06:44 PM   #19
1988TTOP
the green wire with yellow trace u splice that wire any put it on the coil
__________________
Old 08-12-2009, 07:16 PM   #20
SonicBlueFiveSlow
1989 Ford Mustang
Quote:
No, splice your wire going to the negative side of the coil or the tach out on your ignition/distributor or whatever your setup is to the wire going into the connector underneath the booster. For my car, I just snipped the wire a couple inches before the connector and soldered in my wire that goes to the tach port on my distributor.
__________________
351c, 351w, box, boxed, camshafts, carb, carbd, crane, efi, ignition, lower, lunati, mallory, mustangs, swap, upper, voodoo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
