I have everything out of the car that I will not need, except fuel pump and lines. A/C is gone, the computer harness is gone. Its amazing how the engine bay cleans up with all that gone. I picked up a set of Gt40ps yesturday.
Now...as far as vacumn lines, what can I take out?
__________________
F**K THAT FUEL INJECTION S**
88' GT - GT40P's, Comp 986 vavle springs, Comp xe276hr cam, Comp Magnum 1.7 roller rockers, Comp Pushrods, Edelbrock 289 Performer 4bbl intake, Holley 650, BBK Longtubes, BBK shorty o/r H-Pipe, Dumped flowmasters, Ford 9mm wires, Crane PS91 coil, MSD 6A, Ford Racing 4.10 gears, Ford Racing King Cobra clutch, Hurst shifter, Holley Blue Fuel pump, jegs 12 gallon pro-street fuel cell, Holley Regulator, blood sweat and tears
Vacuum lines...pretty much everything. Obviously everything smog related is gonna disappear. Unless you're keeping cruise control, the only thing you should have left vacuum wise should be a line to the booster, a line going into the firewall for heater controls and vacuum advance.
Oh and a carb'd engine bay does clean up nicely doesn't it?
My junk:
__________________
Quote:
Originally Posted by cch
bahaha 'magine there was more side bulge then Rosie O'donnel in spandex.
Ok I dont have heat, my cruise control doesnt work and I dont care, so I can rip every vacumn line off in the engine bay and coming out of the firewall except the brake booster?
__________________
Double pumpers eat gas I heard. And im sick of fuel injection, I could throw a carb on a bone stock car if I wanted too. Doesnt matter if its a mild build or not, I feel like going carbed. Btw this setup is temporary.
__________________
double pumpers can eat the gas. all you have to do is keep your foot out of it. i would mount the fuel pressure regulator on the core support. due to extra fuel in the lines. iv done both from stut tower to carb and core support to carb. the core support way i pick up 2 mph at the track. the lines are longer and acts like a resivoir. just a thought.
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
it all depends on what your trying to do, i just thought id let you know if you like going to the track vac sec. carbs dont 60' very well. the eddy avs carb you could probably tune to 60' well but with a hooley the dp is the only way to go for real high performance. also if your 5spd i dont think id bother w/vacuum secondary either
carbs work good. in a mild setup your gonna lose some torque though
About the fuel lines, the stock size is too small or will they work? If I can use them I just need to hard wire the fuel pump and get a regulator right?
jay
__________________
