This car just runs funny sometimes. It'll be at idle, like 8 or 900 rpm. Open the throttle and it slumps down to about 500 rpm and then revs from there. Once it starts revving everything is great.
It's just that one time, from idle only, that this occurs.
Any ideas?
o and, it's the 5.0 h o setup.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
This battle station is fully operational
Now all we need is a little energon, and a lot of luck... -OP
I believe that even the older speed density systems used an IAC valve. And I know that it's secondary function is to ensure a smooth transition from idle. Idling at 900 rpm seems high also which could point at the IAC as well.
__________________ ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
I had already cleaned out the IAC as well as I could twice. I thought it made a difference the first time but I couldn't tell the second.
I replaced it.
...Finally got around to checkin' codes via KOEO. 22 and 32 were the only ones present.
so 22= Manifold Absolute Pressure/Barometric Pressure Sensor Out Of Self Test Range (O,M,R). I replaced that bad boy and the car seems able to correct its idle as opposed to wavering between 500 and 900 rpm when started(this was an intermittent symptom). Throttle response seems fine now, actually.
but 32= EGR Valve Position/Pressure Feedback EGR Voltage Below Closed Voltage. 0.24 volts (O,M,R) I'm not sure how to interpret this; if it means the EGR is stuck shut, then that's probably desirable, eh? I've seen that it's a pretty popular move to eliminate this system altogether.
The car does still seem to have to rediscover some kind of balance in order to idle properly immediately after a start sometimes, and I wonder if that's EGR related or if there's something else going on that wouldn't be present in the diagnostic... memory?
__________________
Reason: a detail
