Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 12:24 PM   #1
richmustang1880
Vehicle: 1989
Default carb gas leak
one of the fuel inlet ports threads are partially stripped and gas is leaking from it how do i fix this. should i just jb weld the fitting to the carb? and i stil cant figure out what carb i have there is no list number so if someone could help me out
__________________
89 gt hatchback
carb conversion
mods: upr coil overs/kyb agx struts,upr cc plates, bbk lt headers, bbk o/r hpipe, flomaster 40s, crosswind intake, edelbrock 600cfm carb, MGW shifter, bbk subframe connectors, 3.73's
http://www.cardomain.com/ride/2405604
richmustang1880 is offline   Reply With Quote
Old 09-14-2009, 01:14 PM   #2
1988TTOP
Vehicle: 1988 GT TTOP
do not jb weld that think man what if u have to take it off for what ever reason how striped is it if it still holds it good try some Teflon tape or jusr get a different bowl
__________________
1988 Gt TTOPS 1 1/2 IN LOWERING SPRINGS KYB ADJ SHOCKS MSD COIL FRPP WIRES LONG TUBES O/R X PIPE FLOWMASTERS KING CORBA CLUTCH MGW SHORT THROW SHIFTER F CAM CRAN VALVE SPRINGS ROLLER ROCKERS 650 DP HOLLEY UPPER & LOWER CONTROL ARMS 4.10 GEARS
1988TTOP is offline   Reply With Quote
Old 09-14-2009, 01:32 PM   #3
richmustang1880
Vehicle: 1989
getting a different bowl thanks for the reasoning i was just freaking out a little
__________________
89 gt hatchback
carb conversion
Old 09-14-2009, 02:21 PM   #4
1988TTOP
that or try to repair the threads
__________________
Old 09-14-2009, 10:52 PM   #5
richmustang1880
Vehicle: 1989
talked to my friend and mechanic recomended going with a edelbrock and so i did
__________________
89 gt hatchback
carb conversion
Old 09-20-2009, 05:31 PM   #6
86blackgt
86blackgt's Avatar
Vehicle: 86 ford mustang
what size is the holley? holleys are good for the track edelbrock are good for the street.
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
86blackgt is offline   Reply With Quote
Old 09-21-2009, 11:16 AM   #7
richmustang1880
Vehicle: 1989
the holley is a 650 but it was worked it was way to much for the engine
__________________
89 gt hatchback
carb conversion
2000, carb, carburetor, engine, gas, gt, helicoil, inlet, jb, leaking, leaks, mustang, stripped, threads, weld
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
