Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-20-2009, 09:30 PM   #1
whatitis
Default Dissy question
I am ready to get a distributor for my carb conversion. Seems like so many choices The HEI ones on E bay for around 50 bucks are tempting but I want some advise from the experts. I'm on a budget so the High performance stuff is out of the question. Another question, I have a Performer intake, how do you put the PVC system back when you do a conversion ?
whatitis is offline   Reply With Quote
Old 09-26-2009, 05:31 PM   #2
wagontrain
1978 Ford Fairmont
wagontrain's Avatar
Vehicle: 78 Ford Fairmont
I have never used one of those distributors off ebay,so I can not comment on that,best of luck.On the pvc system, put a grommet in valve cover for a PCV valve and hook it to the big Vacuum port on carb,the oil filler cap needs to be filtered somehow so air can get into the engine.
__________________
Worlds fastest 357 c.i.d.,With one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior,1983 Crimson Cat,Mercury Capri RS in my garage.(8.31 166)Under Reconstruction!
1978 Ford Fairmont Stationwagon,351 Windsor,Turbo-350,8.8 31 spline axles,steel spool,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Track locator,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.470,440@wheel
wagontrain is offline   Reply With Quote
Old 09-30-2009, 01:25 PM   #3
highskewlmustnglvr86
1986 Ford Mustang
i have used the ebay hei distributor and with my personal experiences it kept blowing ignition modules. i believe they may have been due to my car being wired wrong, as i ordered a fireball ignition module once to replace it and it also blew. But they seem to be decently built, and i believe they came with an iron gear also, which i believe you should change.. just my .02
__________________
1993 corral reef hatch-sold
1986 notch- new project
highskewlmustnglvr86 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
