Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-25-2009, 06:34 PM   #1
richmustang1880
Vehicle: 1989
Default fuel pressure
the mechanic at the shop said he set the fuel pressure to 7lbs my fuel pressure gauge is reading 3 - 3.5 at idle and temp. i didnt look when the car was still at the shop he just said it was set and i went home. more likely my gauge is bad or i need to reset the fuel pressure?
__________________
89 gt hatchback
carb conversion
mods: upr coil overs/kyb agx struts,upr cc plates, bbk lt headers, bbk o/r hpipe, flomaster 40s, crosswind intake, edelbrock 600cfm carb, MGW shifter, bbk subframe connectors, 3.73's
http://www.cardomain.com/ride/2405604
richmustang1880 is offline   Reply With Quote
Old 09-26-2009, 08:21 AM   #2
richmustang1880
Vehicle: 1989
when should i set the fuel pressure with just the fuel pump on or at temp and idle?
__________________
89 gt hatchback
carb conversion
Old 09-26-2009, 03:14 PM   #3
86blackgt
86blackgt's Avatar
Vehicle: 86 ford mustang
either way it shouldn't change.
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
86blackgt is offline   Reply With Quote
600, carb, cfm, fuel, pressure, set
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
