Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-30-2009, 01:21 PM   #1
highskewlmustnglvr86
1986 Ford Mustang
Default Car wont start!
So i have an 86 coupe with a carbed 5.0 recently it stopped running and im almost lost. now it will turn over but will not crank. i replaced the msd box, the coil, the wires, sparkplugs, cap , and rotor, and it still will not fire. It used a test light and saw that power was going to the positive side of the coil, but the coil isnt sending the spark to the distributor. What could cause this? Everyonce in a blue moon the car will fire, but other times it simply isnt getting spark. Any help/advice would be greatly appreciated.
__________________
1993 corral reef hatch-sold
1986 notch- new project
highskewlmustnglvr86 is offline   Reply With Quote
Old 10-01-2009, 02:21 PM   #2
1986 Ford Mustang
could it maybe be the pick up in the distributor? this is my guess, and will be what i change next.
__________________
Old 10-01-2009, 02:34 PM   #3
7 UP Mustang
Vehicle: 1990 5.0 LX 7 UP and 2009 Premium Convertible
Send a message via AIM to 7 UP Mustang Send a message via Yahoo to 7 UP Mustang
Make sure the distributor is turning also. With the cap off bump the engine to see if the rotor is rotating. Does this year have the TFI module like my 1990 5.0 does, on that I am not sure if you have it or not. Sounds like you have verified the primary side with your test light, but sounds like it is not getting the secondary side which is for the spark to the plugs.
7 UP Mustang is offline   Reply With Quote
Old 10-03-2009, 09:09 AM   #4
JPJP
Also make sure one of those wires hasn't jiggled a little loose at the distributor making a weak connection.
JPJP is offline   Reply With Quote
Old 10-05-2009, 01:16 PM   #5
jayh88gt
id look into the duraspark box on the strut tower unless the msd takes its place, those used to go bad way back in the 80's
jayh88gt is offline   Reply With Quote
Old 11-02-2009, 06:23 PM   #6
redemption
1989 Ford Mustang
redemption's Avatar
Start from the simple to the extensive
mabye a ground got disconnnected?
coil gone bad?
did you try cranking it and seeing if the coil is working,?
__________________
357w Heads up and kicking ass
redemption is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
