Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-04-2009, 05:47 AM   #1
stefke
Vehicle: 1970 coupe + 1966 coupe
Default In need of torque wrench settings
I'm currently rebuilding an '86 5.0 HO, that's going into a 1970 coupe. Prob. next friday my heads and crank will be ready, so i can install them. But i don't have the manual for this type of engine, i do have a workshop manual for to 64-73 (V8) models.
The order of tightning the heads, crankshaft, inlet etc, is that the same order i can use for the 5.0?
I could also use some torque setting, like main cabs, rods, heads, flywheel etc. Me being in europe, it's not easy to get a decent manual specific for this engine.
Could you guys help me out?
stefke is offline   Reply With Quote
Old 10-04-2009, 02:48 PM   #2
86blackgt
86blackgt's Avatar
Vehicle: 86 ford mustang
mains 60
rods 35
heads 85
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
86blackgt is offline   Reply With Quote
Old 10-11-2009, 09:09 PM   #3
tinman
Vehicle: 84 Mustang, 59 Ranchero
My manual says.........
Mains 60 ft/lb.
Rods 19-42 ft/lbs.
Cylinder heads 65-72 ft/lbs.
Always do the torque in 2 steps. Like on a main cap bolt, first go to 30 ft/lbs then on to 60 ft/lbs.
Manuals can easily be bought from Amazon.com BTW.....
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
tinman is offline   Reply With Quote
Old 10-24-2009, 12:10 PM   #4
stefke
So i finally got the crankshaft an heads back. Crank has been grinded -010". I just put the crank, pistons, rods into place and thightened them to spec.
I also put the camshaft in, (before the crankshaft) but now i'm stuck. I need to know how the markings on the gears have to come. Can you provide me with a picture?
Also, which manual do you have? And does it have a chapter specific to the speed density setup and wiring? I did a search, but i don't know which book to buy.
I had to replace the exhaust valves too (leak), but no one has them in stock here. With a little luck i'll have them next week or the following week.
Thx,
Old 10-24-2009, 11:28 PM   #5
tinman
There should be a punch mark on each of the gears. The marks must face each other. Small gear (sprocket really) goes on the crank and the mark must be on top. Big gear goes on cam, mark to the bottom facing the crank gear. Engine will be about TDC when the keyway of the crank is facing upwards.
__________________
Old 10-24-2009, 11:30 PM   #6
tinman
BTW, my favorite manual is Chiltons cost's about $20 over here it has wiring diagrams in it too........
Amazon should be able to get you one.
__________________
65, carburetor, footpounds, pics, proper, setting, torque, wrench
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
