Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 11:00 PM   #11
jayh88gt
stock rod length is 5.09
93's had hyper pistons
86-up have true dual exhaust
85-up has factory headers, though crimped and pathetic
86-up have 8.8 limited slip rear
86-88 are speed density
89-up are mass air
jayh88gt is offline   Reply With Quote
Old 10-24-2009, 11:44 PM   #12
tinman
Vehicle: 84 Mustang, 59 Ranchero
Stock rod is 5.040" long.
No, you really can't convert to 4 bolt mains, Ford god will send you to hell...........
Cast iron block, started life in 1962 @221CID.
2 valve heads, cast iron castings.
Very good book about 5.0 engines/Fox body Mustangs is...........Mustang 5.0 by Al Kirshenbaum. Ford racing part # M-1832-Z4 ISBN 0-8376-0210-6
Amazon should have it. Tells you more than you'll want to know.........
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
tinman is offline   Reply With Quote
Old 10-25-2009, 02:16 AM   #13
grindman620
grindman620's Avatar
Vehicle: 2008 Ford Mustang!!!!
great thanks for all the info guys, if i need more ill be sure to holla back!
__________________
2008 4.0
1993 5.0
grindman620 is offline   Reply With Quote
Old 10-27-2009, 12:22 AM   #14
SuperHoss
Vehicle: 1966
The 302 started life in the 1968, which at the time was a 289 with a slightly longer stroke and shorter rods (289 = 2.87in stroke and 5.155in rods, and 302 = 3.00in stroke and 5.088in rods)...the 302 block also have deeper cylinder skirts than the 260/289 blocks
The 5.0 roller is a piece all to itself, I'll use the '89 specs
-50.0 oz balance (instead of the old 28.0 oz balance from the 60s)
-hydraulic roller cam with roughly .444 lift
-SEFI (one injector per cylinder and a mass airflow sensor)
-factory shorty headers
-cast iron block and heads with 2 bolt mains
-forged rods and pistons
the further into the 90s you go the more complicated they get...some models come with GT-40 heads and intake while later ones come with GT-40P heads while others still use the old stock E7 heads. 1994 was the last year of the 5.0 in the Mustang...1995 forward was the use of the 4.6 modular motor.
SuperHoss is offline   Reply With Quote
Old 10-27-2009, 08:08 AM   #15
AYEOH5.0
1995 was the last year of the 5.0 bud. 96+ use 4.6 or 5.4 if you have a 2000 cobra R =)
__________________
1989 Mustang GT - 347 stroker
AYEOH5.0 is offline   Reply With Quote
Old 10-27-2009, 08:46 AM   #16
Pony123
2006 Ford Mustang
Vehicle: 2006, Ford Mustang GT
Check your manual. car specifications you can go to cars.com or edmunds.com but its basic measurements not too too too speciefic
__________________
Pony123 is offline   Reply With Quote
Old 10-27-2009, 11:40 AM   #17
SuperHoss
Vehicle: 1966
An honest mistake...
1985, 1989, 302, 50, 87, compression, engine, ford, gt, heads, internals, measurement, mustang, piston, ratio, specs, stock, stroke
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
