Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-17-2009, 01:11 AM   #1
grindman620
grindman620's Avatar
Vehicle: 2008 Ford Mustang!!!!
Question Stock 5.0 motor specs????
Does anyone have a website that lists all the specs for our 5.0's???? Like in depth info would be helpful.
__________________
2008 4.0
1993 5.0
grindman620 is offline   Reply With Quote
Old 10-17-2009, 02:43 PM   #2
grindman620
no one????????
__________________
2008 4.0
1993 5.0
Old 10-17-2009, 09:50 PM   #3
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
what spec exactly?
__________________
mattdel is offline   Reply With Quote
Old 10-18-2009, 02:38 AM   #4
grindman620
basically everything i can. like what material the block is made from, dimensions, how many valves, what type bolt main. i know you are probably laughing at me, but i really want to learn about this 5 oh. it would be great if there was a website that listed all the stats about the stock motor.
__________________
2008 4.0
1993 5.0
Old 10-18-2009, 04:34 AM   #5
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Quote:
well, the block is cast iron(as are the stock heads), 2 valves per cylinder, 2 bolt main(can be drilled for 4).
the most common foxes were the late 80s early 90s, which came with 225bhp and 300btrq.. about 9.0:1 compression ratio, 4" bore with a 3" stroke, 5.4" rod length(i think)..
i'll try and find some more.
__________________
Old 10-18-2009, 12:19 PM   #6
Black89LX
Vehicle: 1989, Ford, Mustang
this is for the 87-93 5.0
forged internals unless its a 93 motor, then it had cast pistons, hydraulic roller lifters, roller cam 266* duration .444 lift, 60-64cc combustion chambers, 60 mm throttle body
__________________
http://www.cardomain.com/ride/2672103
With 2.73's
Best 1/4
15.647 @ 89.46 with a 0.25 R/T
Best 1/8
10.135 @ 71.77 with a 0.18 R/T
With 4.10's
Best 1/4
14.854 @93.7 with a -.074 REDLIGHT
Best 1/8
9.597 @ 74.01 with a .098 R/T
Black89LX is offline   Reply With Quote
Old 10-18-2009, 02:35 PM   #7
grindman620
thanks guys, i have a 92 GT so those specs should be what i was looking for. when you say its a 2 bolt main, but could be drilled for a 4...........how does that work? i have never heard of that.
__________________
2008 4.0
1993 5.0
Old 10-20-2009, 11:35 AM   #8
grindman620
anyone? how do you turn a 2 bolt main to a 4?
__________________
2008 4.0
1993 5.0
Old 10-20-2009, 04:58 PM   #9
mattdel
mattdel's Avatar
Vehicle: 1986 LX
there really is not enough material in the web to convert a 302 to a proper four bolt main configuration. even if you made your own main caps, and used bolts that were small enough to prevent creating stress risers in the block, the gain in strength would be minimal at best. if you want a four bolt main 302, then find on old boss 302 block, buy a new boss 302 block, or get an after market block.
unless you're shooting for 800+hp or 7000+rpm, a 2bolt will be fine.
__________________
Old 10-20-2009, 07:22 PM   #10
grindman620
i gotcha, i dont think that i am aiming quite that high in the hp#'s..........i would be quite happy with 400+ (after supercharging too lol)
__________________
2008 4.0
1993 5.0
1985, 1989, 302, 50, 87, compression, engine, ford, gt, heads, internals, measurement, mustang, piston, ratio, specs, stock, stroke
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
