timing question
Hey all so I am new at this mustang thing. Used to have a honda trying to resto project on a 89 GT. Right now just working on regular motor needs. how do I know if I need a new cap n rotor?? I changed the spark plugs and put new wires on cap look ****in new.. Please help )
alright i took the easy (and more expensive) way out, and just took it to a shop, they said all the cylinders were hitting, one was stronger than the rest, and the most likely cause of my misfire is the jets in the carb, i'm guessing it's lean down low and maybe a little bit lean up top, because when the 4 barrels open up there's less of a misfire
Look on the underside of the cap. If it looks burnt, or corroded, replace it.
If you replace the cap, replace the rotor also.
If you've already replaced the plugs and wires, I would just replace the cap and rotor anyway. I like to do it all at once.
okay, it's running just a tad better it seems, still misfires and pops though... it's not like it's running HORRIBLE, just worse than what it should. so instead of being a ~12.2 car, it's more like a ~13.0 car, i'm just gonna keep running this motor easy til i find another one to replace it and stroke that
Calizic
08-28-2015 01:46 PM
