How do I put a 5.0 in my 83 GLX Convertible?
Yup,
unbolt the engine and trans
find the correct flexplate
bolt 5.0 to trans with 5.0 motor mounts
replace trans crossmember with a double hump to run dual exhaust
wire up the motor and start her up.....
also pull the instrument cluster and spin the **** under the tach from the 6 to the 8 so it will read the rpms correctly
Its not hard and thats exactly what I did with my 83. Also you don't have a c4, its a c5 (well it should be). Same thing for the most part but there are a couple differences. With the c5 you will need a 164 tooth flexplate.
The engine is called a essex v6 adder.........
The Ford Essex V6 engine was a 90° V6 engine family built by Ford Motor Company at the Essex Engine Plant in Windsor, Ontario, Canada. Unlike the British Essex V6, the Canadian Essex used a 90° V configuration, in addition to having different displacements and valvetrains. With Ford's Essex Engine Plant idled as of November 2007, this engine was succeeded by the Ford Duratec 35.
Cannibal_carnies
03-02-2023 06:17 PM
dochawk
08-25-2015 08:25 AM
