Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Carb size 750 or 850?
Old 10-10-2010, 05:28 PM
GT350son
GT350son's Avatar
Default Carb size 750 or 850?
I'm building a 347 stroker with
225cc AFR Heads
Lunati Cam retrofit - Duration 300 int / 310 exh, Lift .560 int /.576 exh
Edelbrock Performer Air-Gap
And would like to know what size holley carb you guys suggest.
Its going to be a street/heavy strip car
Thank you in advanced
GT350son is offline
Old 10-11-2010, 02:44 PM
67mustang302
67mustang302's Avatar
Like I said in the other thread, it depends on the carb and how you plan to use the car. If you're really concerned get an 850 with annular boosters and it won't have problems.
67mustang302 is offline
Old 10-11-2010, 03:04 PM
GT350son
GT350son's Avatar
Just posted in this section to see if anyone here had any input. And yes I have been looking into a 830cfm annular
GT350son is offline
Old 10-12-2010, 11:15 AM
67mustang302
Get a mechanical secondary though. Easier to tune.
Old 10-12-2010, 02:06 PM
GT350son
GT350son's Avatar
Probably gonna go with this one.
http://www.summitracing.com/parts/HLY-0-9380/
GT350son is offline
Old 10-13-2010, 12:53 PM
67mustang302
http://www.summitracing.com/search/D...e/?Ns=Rank|Asc
About the same money, or slightly more, and you'll get a MUCH better quality carburetor with far more tunability. Holleys are made of zinc, which is potmetal....so they weigh a ton and can get more easily damaged, whereas the QFT(or equivalent) are made from AL alloy. And they all come with at least good downleg boosters, some with annular...whereas most Holleys come with very old style and less effective straight leg boosters.
Old 10-13-2010, 04:55 PM
GT350son
GT350son's Avatar
What's the difference between Holley and Quick Fuel?
GT350son is offline
Old 10-14-2010, 12:53 PM
67mustang302
QFT's have better boosters, with 2 booster options(downleg or annular). Holley's are usually just straight leg(crappy), sometimes downleg(rarely annular). The Holley 4150HP you can change jets or air bleeds, standard Holley's jets only. All quick fuels come with changable jets, air bleeds, idle feed restrictors and power valve channel restrictors. All QFT's are also pre tapped in the metering block for changing emulsion with restrictors(just drill out the emulsion hole and drop restrictors in), and some come pre-set with emulsion restrictors already.
That and the metering blocks are billet on the QFT's, the throttle plates are also billet, and the bodies are cast aluminum. Holley's are made of zinc, which is about 2-3x heavier and zinc is basically pot metal(cheap and easily damaged). QFT's also come with actual glass sight plugs for setting float level.
And QFT has good customer service.
Demodulates
09-18-2015 11:14 AM
Sminemann
09-17-2015 09:24 AM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Carb size 750 or 850?
