Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
88 LX 5.0 acting strange
Old 10-14-2010, 07:54 AM
kolb02
kolb02's Avatar
Default 88 LX 5.0 acting strange
I just bought this car and sometimes it just die's when at idle and other times when Im driving and come to a stop and put it in park or neutral it idles really high like 1300-1500 rpm. Whats the deal here? What should I replace or check?
kolb02 is offline
Old 11-09-2010, 06:01 PM
JPJP
JPJP's Avatar
Check your IAC Valve. Try unplugging it to see idle characteristics.
I recommend cleaning it our really well and watching for improvement.
You may want to try restricting the air flow thru it to keep idle speed down. Some people will epoxy a 1/2 Dia. copper pipe in (the inlet side) air passage of the IAC valve and then drill a hole in till they get the idle speed they want. I hear drilling a 3/16 dia. is the smallest hole size you should try. I think I went with a 7/32 hole in mine. Some people go a little larger but I don't remember the maximum recommended size.
JPJP is offline
Urambo Tauro
10-05-2015 09:37 PM
svfetter
10-05-2015 11:39 AM
Matt's 95 Stang
10-05-2015 07:16 AM
wraith777
09-28-2015 10:49 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: 88 LX 5.0 acting strange
