Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
1986 gt carbed
Old 06-29-2011, 03:22 PM
load1234
load1234's Avatar
Default 1986 gt carbed
help! i need some pointers on tuning my 86 gt. i recently changed from efi to a 650 holley doublepumper on a rpm air gap intake. it has a 6AL box with a probillet distro. i didnt change the heads but i was wondering if i should have. i dont know if there is really any difference in the efi heads compared to the carbed heads from the earlier cars. also, i put a 85 fuel pump in to reduce the fuel pressure. any help would be great
load1234 is offline
Old 06-29-2011, 03:29 PM
mattdel
mattdel's Avatar
i missed the question...
mattdel is offline
Old 06-29-2011, 03:32 PM
load1234
load1234's Avatar
i forgot to mention that the carb has 67 jets in the front and 69 jets in the back. the question is, do i need to change the heads? also, it idles fine but when i put my foot into it, it bogs down, then picks up like its getting too much fuel still. sorry i suck at posting things. anyone else with this setup?
load1234 is offline
Old 06-29-2011, 04:05 PM
Venomantidote95
Venomantidote95's Avatar
it would have been cheaper for a MAF conversion! It probably is getting too much fuel, what kind of regulator do you have now and what is the pressure?
Venomantidote95 is offline
Old 06-29-2011, 04:08 PM
jwog666
jwog666's Avatar
what else have you done to the engine? if all you did was rip off the efi and bolt on a double pumper the bog is most likely being caused by the massive ammount of fuel being pumped in by the twin accelerator pumps. on an engine with little to no mods, and low hp a double pumper is overkill and will require alot of tuning to get running properly.
changing heads alone wont help much, but heads, cam, lower gears and/or higher stall converter combined would.
jwog666 is offline
Old 06-30-2011, 01:07 AM
load1234
load1234's Avatar
thanks for the help, i have really only done the top half. i changed the mechanical advance springs in the distributor to the lightest and that has helped mostly. just trying to fine tune it now.
load1234 is offline
Old 06-30-2011, 11:26 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
5 spd or auto tranny??
mjr46 is offline
Old 06-30-2011, 07:55 PM
load1234
load1234's Avatar
5 speed with 3.55 rearend
load1234 is offline
Old 06-30-2011, 11:00 PM
Venomantidote95
Uh oh not 3.55`s put some 4.10`s in there and she`ll be fixed LMFAO! Sorry sorry back on topic!
Old 07-01-2011, 03:50 AM
load1234
load1234's Avatar
well, the gears were free and the install was a case of beer so those 355s were a steal. put a set of early heads and seems to help out some
load1234 is offline
Quick Reply: 1986 gt carbed
