Summit Racing S&S Digital Cd igniton
hello everyone i hope i posed this in the right spot!! (forgive me if i didnt)
well i got this car and it has this box on it Well low down, bought car guy said " car needs to be hooked up he did the easy part he didnt know how to hook up the disturber part of this " well in there book it says well check it out
http://static.summitracing.com/globa...sum-850610.pdf
Scroll down too
FORD IGNITIONS Wiring a Ford TFI with Harness, SUM-850518
you will see how i have to hook it up with that part is done
well here is the Problem i am having is this I dont have a TFI disturber i have a msd one that isnt a TFI it has r wired 1 black 1 black red 1 black violet or pink not sure . I know i need one of these wire to be hooked up to a steady 12v supply so the car will fire ( i dont know) now the system i have if you look up at
FORD IGNITIONS Wiring a Ford DuraSpark using Magnetic Pickup Trigger
its kinda the same disturber i have but different color wires , WHat do you guys think ??? What about a hei Disturber i know that set up 1 hot wire simple hookup ,but i wanna try what i have before i go that way!!?? Here is some pic of the system
Scroll down too
Ok i think i may have gotting this not sure if someone can give me a clue here if i did or not but the red/black goes to the +on the coil and the voilet goes to the- coil and the black grounds to the motor?? did find out this is a motorcraft disturber tho with a msd cap
09-29-2015 03:23 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
