Trick Flow Top End - MustangForums.com
Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Old 04-24-2012, 11:04 AM   #1
lovemygt
Default Trick Flow Top End
It's this combo the best bang for the buck? $2600 + another $1000 for the install plus another $500 or so for the tune? Or can you make 360HP cheaper piecing it together?
http://www.summitracing.com/parts/TFS-K514-360350B/
lovemygt is offline   Reply With Quote
Old 04-26-2012, 04:53 PM   #2
1fast Lorinser
If you do end up going with this combo please us know what is the out come and real HP increase numbers. Thanks
1fast Lorinser is offline   Reply With Quote
Old 04-27-2012, 02:50 PM   #3
Venomantidote95
Venomantidote95's Avatar
Well you wont hit 350 or 360 on the numbers since it was done on and engine dyno and plus for some reason no two engines ever make the same power even with identical parts but you will be with in the area of 280-300rwhp generally is what i have seen them make which is pretty close to the advertised output!
unless you like to spend money a tune isnt a must with that setup a stock ecm can handle it nicely!
Venomantidote95 is offline   Reply With Quote
Old 04-30-2012, 09:57 AM   #4
Gregg@TFS
Yes, the HP number we advertise are at the flywheel. Tuned properly with the items suggested to go with the kit you will make around 300-310 at the tires on average. The kits is great for a daily driver that you can drive anywhere and make reliable HP. If you have further questions please feel free to contact us at 330-630-1555.
Thank you,
Gregg
Trick Flow Tech
Gregg@TFS is offline   Reply With Quote
Old 04-30-2012, 01:36 PM   #5
bluebeastsrt
bluebeastsrt's Avatar
MM&FF just did a write up on that top end kit and they gained 75HP at the rear wheels on a dyno.
bluebeastsrt is offline   Reply With Quote
mysterious water leak zsmart Convertible Tech 2 02-29-2016 09:33 AM
81 Mustang Ghia 2.3 Worth? showoffzx2 4 Cylinder NA and Turbo 6 09-14-2015 09:40 PM
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 03:21 AM
Car meet and cruise Gabe_mlcc Mustang News, Concepts, Rumors & Discussion 0 09-08-2015 12:56 AM
190, carb, end, fastest, flow, foxbody, gt, kit, mustang, reviews, speed, stall, tfs, top, trick, trickflow
