Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
speed density(SD) question.
Old 05-27-2012, 07:43 PM
jst98gtmustang
jst98gtmustang's Avatar
Default speed density(SD) question.
I was wounding a few things since i'm new to 5.0.
Cams.what can i use? i was looking on ford website and some of the cams like the e303 cam and it says..
On EFI engines, performance camshafts work only with mass air induction systems. Will not work with Explorer EEC-V EFI. That mean it won't work cause i don't have a maf?
jst98gtmustang is offline
Old 05-29-2012, 07:57 AM
van-swink85
van-swink85's Avatar
Correct lobe seperation is different
van-swink85 is offline
Old 05-29-2012, 05:35 PM
jst98gtmustang
So what a good cam to use?
Old 05-30-2012, 09:38 AM
mattdel
mattdel's Avatar
You can get a performance cam for a SD setup, it just needs proper lobe timing to maintain vacuum sufficient for MAP readings. The bigger problem is that while you can choose any cam you want (basically), nearly any cam you choose will require a professional tune unless you swap over to MAF, or unless you get a SD specific cam.
mattdel is offline
Old 06-02-2012, 12:30 AM
thegstring
thegstring's Avatar
you'll want to get a Mass Air Flow, a speed density system uses fixed air/fuel curves so if you do anything to take it away from stock airflow (i.e camshaft) it'll be totally lost. A mass air flow meter will learn on the fly and adjust your air/fuel mixture accordingly.
Check this article out:
http://www.musclemustangfastfords.co...n/viewall.html
Very informative.
thegstring is offline
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
BeatnikFink
10-01-2015 08:00 PM
musnicki
09-23-2015 07:11 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Quick Reply: speed density(SD) question.
