Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Change 1994 5.0 to carberator
Old 12-17-2012, 04:10 PM
Bencobys47
Bencobys47's Avatar
Default Change 1994 5.0 to carberator
I put motor and 5speed in 1941 chevy pu
Bencobys47 is offline
Old 12-17-2012, 04:51 PM
mattdel
mattdel's Avatar
In Soviet Russia, car drives you!
mattdel is offline
Old 12-17-2012, 05:39 PM
dawson1112
dawson1112's Avatar
Is that a
dawson1112 is offline
Old 12-17-2012, 06:02 PM
Duncan_GT
Duncan_GT's Avatar
What?
Edit: I keep laughing everytime I read Matt's post
Duncan_GT is offline
Old 12-17-2012, 07:07 PM
dawson1112
dawson1112's Avatar
Sorry lol if your asking if it can be done ........Yes it can . You can go about fueling it by using a 5-7 psi electric inline pump . Or if im not mistaken you can use a earlier model timing cover and fuel pump eccentric for the mechanical
pump. As far as ignition goes get a duraspark dizzy with vacuum advance and ignition module with a coil and ballast resistor .
Or you could just get a points dizzy and coil lol
Old 12-17-2012, 07:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
thread = fail
mjr46 is offline
Old 12-17-2012, 08:17 PM
Bencobys47
Bencobys47's Avatar
Do you know how much hp I would lose if I did switch from fuel injection to carb.
And to clarify my first post im rebuilding a 41 chevy pickup and I put a 94mustang gt in it. And since the 41 needed to be rewired a d thats probably pretty costly I figured I would go to carb instead
Old 12-21-2012, 07:28 AM
dawson1112
dawson1112's Avatar
Its not a matter of loosing or gaining any hp. You could achieve either or. depending on what intake you choose and what carb you choose.
Its more a matter of weight/Hp ratio.
Your pushing 1500 more pounds of steel ..
Old 01-15-2013, 07:05 PM
PaladiNSX
PaladiNSX's Avatar
Since the OP is nearly unreadable and I have a similar question, I'm gonna go ahead and hijack this thread for a sec. Apologies in advance.
I have an 85 GT with the engine pulled (and mostly gone, but I still have the intake mani). I picked up a low miles 91 5.0 engine with no EFI and GT40 heads that I want to retrofit a Carb setup on. I'm leaning towards a 650cfm double pumper as this will primarily see road course/autocross duty. I'd like to run an external electric fuel pump in lieu of finding a new timing cover, mech fuel pump, and cam eccentric.
Any articles/resources to get me started? I'm sort of new to the game here and I'm not totally sure what I'm gonna need. What are the "gotcha" parts that are gonna come up in the course of the swap?
PaladiNSX is offline
Old 01-15-2013, 09:16 PM
jthorn9
The Godfather
jthorn9's Avatar
Hahaha....I needed a good laugh today and this thread done it!!!
jthorn9 is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
JT76
09-20-2015 11:32 AM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Change 1994 5.0 to carberator
