Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
voltage on TPS
Old 12-28-2014, 06:57 PM
64bit
64bit's Avatar
Originally Posted by claysstang@att.net
what happens if you cant turn it anymore and only get .92 volts
you do not need to set it to .99v. that is a pure myth that has been discredited many times.
If .92 is where you're at... LEAVE IT
64bit is offline
Old 12-28-2014, 07:43 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
like I said...anywhere from .7 to 1.0 vdc is fine, no need to dremel anything.........it's a comnplete waste to try to set it to some mythical setting of .92 or .98 the ecc iv programming is not fixed on those two voltages
mjr46 is offline
Old 01-06-2015, 08:48 AM
Foureyed
Foureyed's Avatar
I don't think anyone said anything about "fixed" settings.
Foureyed is offline
jwog666
12-27-2021 08:09 PM
69MustangCoupe393cid
10-03-2015 10:33 AM
TfcCDR
09-14-2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: voltage on TPS
