Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
View Poll Results: WAT DO?
Carb'd
22.22%
leave it EFI
66.67%
go 429
11.11%
sell it and put the money into something else
0%
Voters: 9. You may not vote on this poll
making the jump to carb on a 1995 GTS??
Old 05-31-2014, 03:49 PM
Blk Vert
Blk Vert's Avatar
Sounds like you want to go carb, but you want some support. Soooo Do it! lol keep all your old stuff if you want to go back EFI and then you can sale the carb stuff to up grade your EFI if you want to go back. So do it!
Blk Vert is offline
Old 07-20-2014, 03:32 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
so thinking about this more. apparently ic can just pull the pump use this http://www.latemodelrestoration.com/...l-Sending-Unit and leave my stock sending unit in the tank so the gauge will work. all ill be using would be the fuel lines from this part to supply the carbed setup.
rmodel65 is offline
Old 08-04-2014, 08:36 PM
95gtconvert
95gtconvert's Avatar
I'm doing a carb on a 95 gt soon as well and I'd say it's better even if I'm 17 I grew up on carbs and to me it's easier and cheaper to work on cause you can do it at home
95gtconvert is offline
Granatelli Sales
01-20-2020 12:34 AM
bjdutch2005
03-24-2017 03:38 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: making the jump to carb on a 1995 GTS??
