Going Carbureted - MustangForums.com
Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Old 08-01-2014, 11:00 PM   #1
95gtconvert
95gtconvert's Avatar
Default Going Carbureted
I'm going carbureted soon and I'm just wondering will I need a different hood or a modification to my hood to fit it with the air filter and carb adding a little height to the motor
95gtconvert is offline   Reply With Quote
Old 08-02-2014, 09:21 AM   #2
rmodel65
Yukon Cornelius
rmodel65's Avatar
it will be close you might need to notch the bracing under the hood and use a low profile air cleaner.
rmodel65 is offline   Reply With Quote
Old 08-02-2014, 09:57 AM   #3
95gtconvert
Alright thanks for the info there's nowhere near me that can get a low profile air cleaner or they never have them in stock for some reason
my uncle and I might have an idea to make it look like a cobra r hood while keeping the two little scoops on the hood but that's currently a top secret design
Old 08-13-2014, 08:24 AM   #4
64bit
64bit's Avatar
Youre better off keeping it EFI and setting the car up the right way.
64bit is offline   Reply With Quote
Old 08-15-2014, 11:53 PM   #5
95gtconvert
I don't know how to work on efi unless it's basic maintenance because it's just not what I know and even worse is I don't have the type of budget to make the power I'm looking for with efi
Old 08-17-2014, 09:12 AM   #6
64bit
64bit's Avatar
Quote:
The cost is really irrelevant. Youre going to have to spend more money than you think, converting over to a carb system thats going to make any real power.
Old 08-25-2014, 10:35 PM   #7
95gtconvert
currently at 330 hp without making it a stroker motor but carb is really the only thing my family knows how to work on
Old 08-28-2014, 02:27 PM   #8
prbxfd7
prbxfd7's Avatar
There is alot of info out there on EFI systems. Thought about modding from carb to EFI with because all i knew was EFI. But ended up doing my research and sticking with the carb. Glad i did because i picked up alot of knowledge i wouldn't have had if i went to EFI.
prbxfd7 is offline   Reply With Quote
Old 08-28-2014, 02:29 PM   #9
prbxfd7
prbxfd7's Avatar
Use it as a learning experience, ya know?
Old 08-29-2014, 12:38 AM   #10
95gtconvert
I'm just not good with tuning nor do I want to have to go to someone to have it tuned ,I'm either building it myself or paying out of pocket on a high school budget too have it bored and what not I'm also going to be building a roll cage to fit with the top up, so I think the carb is just better for me
carbureted pcv system smbikes 5.0L (1979-1995) Mustang 4 11-09-2006 05:26 PM
carbureted pcv system smbikes Classic Mustangs (Tech) 19 11-09-2006 03:17 PM
Carburetion vs Port-fuel injection twiceasfastasyou General Tech 5 10-15-2006 09:37 PM
argument thread tokinGLX Off Topic 66 10-07-2006 06:48 AM
Carbureted 5.0 jlauth 5.0L (1979-1995) Mustang 10 12-24-2005 10:16 PM
