Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Anderson N51HR timing advance from stock 14*?
Old 11-18-2014, 06:35 AM
347stroker_carb
347stroker_carb's Avatar
Default Anderson N51HR timing advance from stock 14*?
i have a 347 stroker with the Anderson N51HR cam and need a little help on finding how much i need to advance my timing from the stock 14* from the 302.
i have it set now at 18* and its running decent but it would help to know the exact mark to help solve some of the other issues i have with it.
thanks
CAM SPECS:
AFM N-51HR
226*/234* - 293*/301* - .520"/.528" - .325"/.330" - 110* - 105*/115*
Overlap: 77 degrees.
1.6 Rocker Ratio
Intake Opening: 8* BTDC
Intake Closing: 38* ABDC
Exhaust Opening: 52* BBDC
Exhaust Closing: 2* BTDC
347stroker_carb is offline
Old 11-19-2014, 06:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
thanks
CAM SPECS:
AFM N-51HR
1.6 Rocker Ratio
It depends, I run mine at a base of 19 with total at 36 and all in by 3200 rpms I also run a msd billet distributor that has a tunable mech advance.........what issue are you having?? also most 302's run a base stock of 10 degrees not 14
mjr46 is offline
Old 02-13-2015, 08:35 PM
347stroker_carb
well, the car is still running a little crappy but idk whats wrong with it now..lol..still having a little issue with the timing but running at 16-18 degrees now...may be the distributor, wires, plugs, or ignition box..just trying to narrow it down now...also still need to do a compression test to make sure nothing is losing under the valves..any info or help would be nice..thanks
Old 02-15-2015, 07:25 PM
347stroker_carb
just found out that my distributor was setup for a NOS motor and had its guts ripped out to stop it from advancing the timing to run right....so now its gonna cost around $125 to get the guts put back in and work great. hopefully that is all it is..lol
might also have to check if anyone is or has ran a SUMMIT racing ignition timing module...mine seems crappy and cheap...anyone have feedback?
drfister
05-03-2018 10:38 PM
jlopret
2.3L Eco-Boost Tech
11-19-2015 10:32 AM
yurizx6r
09-07-2015 06:40 PM
Soldier GT
08-12-2015 03:46 PM
FD725
08-11-2015 03:43 AM
Quick Reply: Anderson N51HR timing advance from stock 14*?
